Gday all, purchased a 2013 passat TDI wagon yesterday, second hand with 65000 on the clock. All went fine for the first 100ks until the Speedo started to be unable to hold position. At cruise on the highway the digital display reads 100kph but the analouge display weaves up and down around 5kph. All other systems appear to work well. Is there anyone who can tell me where the connector for the transmission output speed sensor is or if this is an issue you have seen before. Cheers in advance. Matt
Sent from my SM-G930F using Tapatalk
Digital speedo shows the wheel speed being read from the ABS wheel speed sensors.
'Secret' menu in RNS510 shows GPS derived ground speed.
Analogue dial is a stepper motor indicating the wheel speed. If this is moving around on a static speed then the stepper motor in the instrument cluster is likely on the way out.
Luckily in the Passat the instrument cluster does NOT contain the immobilizer (unlike in the Golf, Tiguan etc) and as long the instrument cluster has been reset to 0kms (needs special tools) then a new cluster can be installed using only VCDS to set the coding and adapt the kms to match the ECU.
Mine seemed to be right until around an hour into our first trip( unless I wasn't paying attention before) it seems to be reading a few kph more on the analouge display, plus weaving a little. Just annoying as my 30 year old Nissan has a rock solid speedo, and my 6 year old Volkswagen is all over the place like an old cable speedo! I hope my 3 month warranty covers this because I think I will be back to the dealer Monday morning to have a chat, unless anyone has some inside info on how to fix it. I see another thread on the tdi forums where there is at least 10 other owners complaining of this issue
Thanks kamold. Is this a common issue that you have heard of? I am a diesel technician with a major earthmoving brand and the electronic side of things isn't scary, but I feel that 65000 on the clock is pretty poor for a Speedo failure. I know that the dealership will probably fight me on this, but hopefully not. Is Volkswagen Australia ok to deal with?
Thanks mate, very much appreciated
Hey mate, who’d you get the car off? I’ve found JMC really good to deal with.
