Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Engine warning light.
    Nov 2009
    Sydney NSW
    Quote Originally Posted by Ryeman View Post
    Exactly what I'd have thought......lots of 'blow-by' oily gases to be dealt with at speed under load.
    Maybe I didn't explain it correctly. Is the flogging of the engine related to keeping the catalytic converter free from clogging up? That is probably what they meant when I was told about flogging it.
    Btw, where can I have a Provent 200 installed and at what cost?
    The EGR and Flap cost me about $1400 supplied and installed at Muller and Muller at Lakemba.
    Regards,
    NS
    VW Golf MY09 MkV DSG 2.0 TDi Pacific United Grey
    Opal Head Unit - Jomlook DRL
    WOB = Wolfsburg - Vfl Wolfsburg Deutscher Meister 2009
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Quote Originally Posted by NiekSavio View Post
    Regards,
    NS
    Provent / catchcan fitment kits.
    Oct 2010
    Melbourne, VIC
    Regards,
    NS
    The flogging is to keep the turbocharger vanes from getting jammed with buildup of soot.
    $1400?? Good grief! I have the same light on - a VCDS scan by a very helpful forum member gave a TPS inconsistent reading code so I was fearing this would be the cause. At least I know what to expect
    Meanwhile, the car runs just fine.
    Resident grumpy old fart
    Feb 2014
    Central Vic
    Quote Originally Posted by kaanage View Post
    Oh!
    there was I thinking that was quite cheap.
    Jan 2008
    Sunshine Coast
    EGR flap can be had from ebay uk for about $150 used, and darkside developments have them too from memory. Dead easy to swap out.
    Nov 2009
    Sydney NSW
    Quote Originally Posted by Greg Roles View Post
    I did have a look around at eBay and agree that there probably was a more cost effective way of obtaining parts.
    As I did have the Dub from brand new and wanting it on the road asap without the warning light, I decided to have it fixed and was aware of the possible $$$ involved. Even with the warning light on though, I did not have any driving/performance issues.
    Thank you all heaps for your replies and suggestions, it is much appreciated.
    Regards,
    NS
    Oct 2010
    Melbourne, VIC
    The PD ones are cheap but the CR EGR flaps cost 3 times as much
