The amount of intrusion into the lands depends upon how much work the motor has done. At 200,000km it's much more likely that the bores are glazed rather than the pistons are worn. Really it's a case of inspecting the piston carefully and judging how much wear has taken place. Most of the wear will be on the thrust side. Check (with the new rings fitted) the gap between the ring and the aluminium of the ring groove and see that it is with in tolerance. Also mic the bores from top to bottom east-west and noth-south, then mic the pistons. Again, check that they are within tolerance.Originally Posted by hiho
I've heard many stories of re-ringed 1.5s failing very shortly after rebuilding with new rings and bearings so these checks are a must. If the bores aren't too badly worn you should check ebay US as there are often new piston sets for auction and they go for cheap rices. They are usually Brazilian but although obviously not as good a German they will probably outlast the rest of the carDoes anyone have any experience re-ringing golf diesel motors? The motor that im rebuilding has done 235,000kmsMy own personal experience has been good, but then I caught the motor when they were only glazed.
Thanks for your help!
Matt
