Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Engine Mount Insert - Vibration unbearable?
    Bowral, NSW
    I fitted one thousands of k's ago; it was awful and unbearable for about 1,000km and then suddenly it was amazing. Nearly no vibration and still all of the grip - turns out one of the "lugs" broke off the flat section!
    Engine Mount Insert - Vibration unbearable?-l_neuspeed_221091_torque_arm_insert-jpg
    Not that I'm saying you should mutilate yours; but it fixed all my issues!
    I took it out a few thousand k's later and didn't run one for awhile - now I'm running a Superpro one (I think a 70d?) and I've raised the idle with VCDS to 850rpm. This time it remains intact, yet doesn't feel like a V8 Supercar!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Aug 2011
    vic
    Quote Originally Posted by Mysticality View Post
    I ended up having to just take it out, I have purchased a Diesel one but have not installed it yet (this one here https://www.powerflex.co.uk/road-ser...esel/1916.html)
    Interesting about raising the idle, was that hard? can you link me to the guide? I have VCDS and the cable.
    Bowral, NSW
    Quote Originally Posted by vraptor View Post
    I can't remember how I did it - it was awhile ago. I didn't use a guide, just found it myself; all well and good when you have a technical background!
    I did some googling and found this, though. Ross-Tech: VAG-COM: VW MkIV Info
