Originally Posted by
wai
Just a query,
On vehicles with a DPF, is the take-off point for EGR before or after the DPF?
Thanks.
Before, the EGR is piped directly out ot the log manifold before the turbo, so you get full soot introduction!
In the newer MK6 they have an EGR filter as well intheir even more expansive EGR system, so they are trying to combat the buildup.
Niel, all high speed country driving will do is produce less soot overall as you arenlt in start stop traffic, accelerating, blowing max soot. It's still going to build up eventually. Seems to be a lot of factors, but driving style is definately part of it. Lots of acceleration from zero, produces a lot of soot till it's on boost. Oil quality and overall engine condition will no doubt be a player, but oddly enough EGR addition and lowering combustion temps actually CREATES more soot, so go figure. You add EGR to drop NOX, but in turn increase soot, and block your DPF even quicker.
My idea is to drop combustion temps by other means, for both NOX and turbo safety, and to ditch EGR which becomes quite redundant. It DOES help your car warm up faster though, my TDI is taking a long time to reach temps in winter up here in QLD, be a real problem down south.
