not to mention the provent is made by a VW OEM supplier.
Mann & Hummel (spelling???) have been making stuff for VW for eons.
Are you speaking from experience? Mine would suggest one look at any aftermarket engine appendage would make them wash their hands of the affair.
Why not be open and up front about this with the service department? If you install the Provent and it does no harm to the engine, why can't you just say you're going to fit one and come to some arrangement with any warranty issue? I know a friend who installed an aftermarket turbo in his Nissan a number of years ago and Nissan okayed it.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
For the record my Provent oil "trap" hose started to drip ( letting me know it's full ) and I measured what I drained out. 140mL. This doesn't include what didn't condense, and what is lost from the small leaks in my Provent system hosing ( ie Silastic joins! ). Nor does that include just how much has dripped out since it started several days ago. I drain it at about 3-4k intervals, but I'll quantify this km amount as well from today.
Well, I don't measure accurately what I drain from my Provent hose. But 2 weeks ago I replaced water pump in my T5 and I had intercooler to TB hose off, and as I predicted I could wipe off clean most of the area I could get with a clean rag and as far as I could see using torch I was able to see metal under a thin layer of black deposit. I’m very happy with my Provent set up.
Just listened to a podcast from Snow Performance, the water Methanol injection guys from the USA, and they mention the cleaning effect of this injection, and how it helps stop the very common sludge buildup problem in modern diesels from EGR, especially late model VW TDI's. Seems the aftermarket is very aware of it.
Pulled the EGR, throttle body and manifold today, see my tinker thread.
http://www.vwwatercooled.org.au/newf...998#post438998
The problem is real people.
