Page 24 of 35 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 341
Thread: EGR should we all be more concerned
  1. #231
    Nov 2008
    When the Provent is installed correctly it can't do any harm to the engine, so if there were any warranty issues with the engine or engine management, the proper diagnosing would reveal what was the cause of the fault.
    Are you speaking from experience? Mine would suggest one look at any aftermarket engine appendage would make them wash their hands of the affair.
    Quote Originally Posted by cogdoc View Post
    Keep the factory inlet points, plumb it in an easy to remove fashion, and if you do have an issue, just convert it back to stock.
    Why not be open and up front about this with the service department? If you install the Provent and it does no harm to the engine, why can't you just say you're going to fit one and come to some arrangement with any warranty issue? I know a friend who installed an aftermarket turbo in his Nissan a number of years ago and Nissan okayed it.
  2. #232
    Gosford Central Coast NSW
    not to mention the provent is made by a VW OEM supplier.
    Mann & Hummel (spelling???) have been making stuff for VW for eons.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  3. #233
    Nov 2008
    Interesting. Now, the question remains why VW don't fit it as standard equipment ot their TDIs.
  4. #234
    Adelaide hills, SA
    Quote Originally Posted by CatonaPC© View Post
    Because they don't see/don't want to see it as a problem.
  5. #235
    Apr 2009
    Gippsland Victoria
    ABSOLUTELY!
  6. #236
    Jan 2008
    Sunshine Coast
    For the record my Provent oil "trap" hose started to drip ( letting me know it's full ) and I measured what I drained out. 140mL. This doesn't include what didn't condense, and what is lost from the small leaks in my Provent system hosing ( ie Silastic joins! ). Nor does that include just how much has dripped out since it started several days ago. I drain it at about 3-4k intervals, but I'll quantify this km amount as well from today.
  7. #237
    Adelaide hills, SA
    Well, I don't measure accurately what I drain from my Provent hose. But 2 weeks ago I replaced water pump in my T5 and I had intercooler to TB hose off, and as I predicted I could wipe off clean most of the area I could get with a clean rag and as far as I could see using torch I was able to see metal under a thin layer of black deposit. I’m very happy with my Provent set up.
  8. #238
    Jan 2008
    Sunshine Coast
    Just listened to a podcast from Snow Performance, the water Methanol injection guys from the USA, and they mention the cleaning effect of this injection, and how it helps stop the very common sludge buildup problem in modern diesels from EGR, especially late model VW TDI's. Seems the aftermarket is very aware of it.
  9. #239
    Jan 2008
    Sunshine Coast
    Pulled the EGR, throttle body and manifold today, see my tinker thread.
    http://www.vwwatercooled.org.au/newf...998#post438998
    The problem is real people.
  10. #240
    Apr 2009
    Gippsland Victoria
    Angry
    Top sleuthing. I believed anyway but now convinced.
