Just to rain on your parade Tone ol mate, that link to TDI club covers the MKIV version of TDI, and as yet to my understanding no-one has come up with a simple Vag Com answer for the EGR. It'll happen for sure, but I found that site early on as well, got a Vag Com, hooked it up, and it's all different.
Quite bummed at the time!
A wayne angle block would allow you to block / restrict the EGR, but remember too that the exhaust is used to help warm the engine up, as diesels take a lot longer than petrol given the much lower combustion temps. Less of a problem given where we live, but not so good for our southern brothers.
The Provent drains out into a lower hose, which I just bung up and drain every several thou, but no reason you couldn't rig up a container with a tap etc. The bottom small outlet is gravity drain to wherever you wish. I do get a good 100-200mL each drain though. This bottom drain isn't hooked up to my exhaust, rather the outlet from the provent, being the vapours post filter are. The Provent has an inlet, a filtered outlet ( to exhaust ) and a lower drain for what the inner filter removes from the inlet gasses.
