Tony,
No way I'd pull the manifold, purely for the hassle of the gasket, and mine is virtually clean, and staying that way! You'd get the gasket from any VW dealer such as Austral, but it would still be a mission to replace.
I'll photograph the EGR thing and add it to my thread, don't worry!
Vag Com comes from ross-tech, simply no better option at the moment. The software is free to download, you pay for the cable.
A standard reflash such as Bluefin would be fine EGT wise, they allow for that. I'm aiming for a custom, max effort tune.
A scan guage 2 costs a few hundred, but simply plugs in to your CAN port under the dash, and you get all the readings you could ever want, too easy!
Take your car for a good drive up the coast sometime, this supposedly cleans out a fair bit of sludge, sustained higher speed driving. You'd have to have done 100k plus to be in potential problematic sludge territory from what I undersand of it all. Just pop off the lower rubber inlet hose and you have access to the throttle flap and the EGR valve, you can clean them out a bit from underneath. Don't go nuts with spray cleaners, lest you fill the manifold and have a max rev on next start! Little spray, let it drip back out, repeat!
