Page 14 of 35 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 341
Thread: EGR should we all be more concerned
  1. #131
    penrith,sydney
    [QUOTE=cogdoc;300617]On that note I can't seem to adjust my Provent side pressure regulator. I do remember taking it apart when i got it for a lookie see, but it doesn't want to turn either way. I'm going to get onto Sydney Filter services, where I bought it, and see what they have to say. The Provent manual, I have my original here, is vague in this area. Obviously getting this working is my best solution.
    As for adding stuff to my inlet to clean out what's already there, well, too late...
    I was not able to turn mine either. It seemed to be in the fully open pos. as there was no restriction to air flow. This didnt bother me because there is no restriction in the little pipe going to the inlet . FYI after 5k I drained 120ml from the provent. The inlet to the provent had oil in it, the outlet pipe from provent was bone dry. I noticed the oil level on the dip had gone down 2mm.
  2. #132
    Jan 2008
    Sunshine Coast
    Makes me think I've set it up wrong, as there's still *some* oil getting through. Looking into that next, reworking the setup. The Provent is a serious bit of kit, and shiould be doing a great job....hmmm....
  3. #133
    Adelaide hills, SA
    Quote Originally Posted by cogdoc View Post
    Just make sure that the enf of the drain hose is sealed or connected as per instructions.
  4. #134
    Feb 2009
    Kingsgrove, NSW
    wow, this thread really got me concerned... driving a 1.9 TDi (Octavia). Should I be really concerned? Whats provent? How much soot/dirt/whatever builds up in the EGR? I thought that the temperatures would be hot enough to push out most of the excess soot etc through exhaust...
    Sorry I'm a diesel noob
  5. #135
    Closet Diesel Owners Club President.
    Quote Originally Posted by jacob_1987 View Post
    No actually your not a noob..... a noob is my mother and her friend putting petrol into a diesel. The tractor sound, combine harvester attachment, roof racks, man fanny pack and towball, was not enough of a give away.
    *Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
    Economy at 100kph =5.5L
  6. #136
    Dec 2008
    NSW Sydney
    Yes. Diesel Care & Cure is product code 420.
    If you thinking of getting one, the smaller one ( Inter-Ject LB291/1F (401)) is ok for cleaning jobs and even diagnostics. Second tube on LB291/2F is for measuring fuel injectors flow.
    I have bouth units.
    Always have this one in the van.
    Where did you buy it from and how much was it?
    thanks.
    2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
  7. #137
    Jun 2006
    Sunshine Coast
    Man Provent works for me on T5 and I'm going to plumb it in the Golf very soon, using copper tubes and straight pieces of silicon hose. There is nothing you can safely use for cleaning due to amount of the sludge there. You would have to shrink yourself and flow in with a brush, a bucket and a mop.
    Are there any photos or links on how to install on the T5. I have the provent but not enough experience with the T5 motor.
    Thanks Peter
    2018 Skoda Superb TDI
    2010 Skoda Superb TDI
    2009 Golf VI 118 TSI
    2006 Multivan TDI SOLD
  8. #138
    Adelaide hills, SA
    Quote Originally Posted by HiTorque View Post
    thanks.
    From Inter-Ject. Check your PM.
  9. #139
    Adelaide hills, SA
    Quote Originally Posted by coastie View Post
    Thanks Peter
    You need 1500mm silicon hose (diameter is 23mm internal and 33mm external), drain hose 12mm dia 1m long, 4 clamps, 500mm flat steel 25x3, M6x25mm bolt, 6mmflat washer big dia , a pice of rubber or cork to insulate bracket from the body, 2x M8x40 bolts, 2x M8 nut and washers to bolt the provent to the bracket, plastic ties to tie rubber spacer to the intercooler pipe (see pictures). If you don't have a welder you could use 25mm angle steel instead of flat steel.
    1 more picture in next post
  10. #140
    Adelaide hills, SA
    Provent installed in T5 128kW 2005
    It is important that 12mm drain hose at the bottom of Provent is correctly connected or sealed (if sealed,than you have to drain it from time to time).
    The copper tubing can be use if space is limited. Short pieces of silicon hoses (4) would connect copper tubing to inlet and outlet.
    Hint:Silicon hoses are more suited (withstand higher temperatures) they will also stretch more than the rubber one if you try fit it on bigger diameter tubing.
    23mm inside dia goes nicely on 25 mm ports on the Provent.
    Do not use PVC hoses.
