Page 10 of 35 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 341
Thread: EGR should we all be more concerned
  1. #91
    Canberra
    Quote Originally Posted by HiTorque View Post
    Also someone suggested cleaning method - driving in 3 gear at 100-110km/h for 30 km.
    I'm curious, what is the theory behind that ie how is that supposed to remove the gunk ?
  2. #92
    Jan 2008
    Sunshine Coast
    High sustained rev's, engine runs hot, trying to suck more in?
    I'd go the injection / physical clean route personally.....
  3. #93
    Jan 2009
    could the intake manifold be used as a sludge indicator?
    I ask cause it does seem like the easiest part to get to.
    or is it possible for the intake manifold to be clean and all the other pipes and stuff dirty?
  4. #94
    Sep 2008
    Wondering about the design of CCV separators in various models. I read on Mann and Hummel's web site I think about how they do OEM design of CCV separators that are integrated into plastic rocker covers for VW.
    So I was wondering if older models without such integrated CCV separators are more of problem for gunking than newer models.
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
  5. #95
    Jan 2008
    Sunshine Coast
    The oil separation has improved in line with compression and power output, as it should. Higher compression, higher mean effective pressure per explosion, more blowby, more crankcase pressure. I'd reckon they are all pretty similar, it's just the 1.9 has been round longer, more higher milage units out there, more showing sludge problems. The good news for you is "TDI club" has plenty on info on using Vag Com to diminish the EGR in the 1.9 to next to nothing, solving the sludge problem. Not so as yet for the 2.0. Go look at their site mate!
  6. #96
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by chisler View Post
    Ignore the white dots, erasing other labels. Sludgeville is outlined in yellow, but includes inlet ports in the head.
  7. #97
    Quote Originally Posted by cogdoc View Post
    thats great news. Does this mean a Provent does NOT need to be installed?
  8. #98
    Jan 2008
    Sunshine Coast
    Mate, if I had your engine, I'd Vag com down the EGR, and keep an eye on things. You'll still get stock levels of oil vapor going through the engine, but little to no exhaust to mix with it to form the sludge. In short, probably no need for a Provent. Search on TDI club, lots of info on this, how to etc etc.
  9. #99
    Jan 2008
    Sunshine Coast
    "race pipe" from Allard, EGR and flap delete, but will throw an error light because of reduced EGR flow. A sexy item all the same.
    http://forums.tdiclub.com/showthread...rning+down+egr
    A link to turning down the 1.9 using vag com..... section 7h. Lots of power up tips for you 1.9 guys in the FAQ too.
    I also have read about an "intercooler filter" in the 1.9, and this can block up and become a restriction. Something else to investigate little oilers! May be a US only thing.
  10. #100
    melbourne
    cheers cog.
    i've seen some literature on turning down egr with vag com- that wouldnt forfeit any of the "runaway safetys" of the engine, would it? it sorta makes sense that it might.
    also, seeing as egr assists in the warming up process, would this also be forfeited? or is that just if you block off egr completely?
    as for the intercooler filter- is that what countless mk4 tdi'ers refer to as the "snow screen"?
