Page 33 of 35 FirstFirst ... 233132333435 LastLast
Results 321 to 330 of 341
Thread: EGR should we all be more concerned
  1. #321
    Adelaide hills, SA
    Quote Originally Posted by Johnnojack View Post
    Since blanking off a greater proportion of EGR the engine seems to be idling faster, (1000rpm) I think it used to be about 900rpm. (1.9TDI)
    Are the two related?
    Remove the restrictor you put in there and I can take care of your EGR in the software with the performance tune, together with other useful software updates.
  2. #322
    Mar 2011
    Sunshine Coast
    Have spent the day reading this thread from start to finish, as my 2011 Tiguan TDI with 120,000km, all highway driving to Brisbane and back to the Sunshine Coast showed an Engine Management System fault which turned into a Cat Converter icon and became an EGR valve replacement with the local dealer after diagnostics (cost nearly $2000). In shock, I started to look for answers, as this car is starting to seriously cost money. I have just paid $800 plus for a service three weeks ago. I had a Volvo 240 doing the same run for 20 years which reached 750,000 km without taking the head off and moved to this VW diesel with unrealistic expectations it seems.
    I would have thought the long highway driving I do would have stopped/minimised these problems but my question is whether the current VW issues with software and pollution control can be linked to the issues discussed in this thread, as there have been some oblique comments regarding pollution control and EGR made here.
  3. #323
    Jan 2011
    Adelaide SA
    Well only 12 months and 12000ks later and the 1.9 was using more fuel (average over 5l/100 rather than under 5 on computer) so pulled off the EGR, it had around 5-6mm coating of wet (oily) carbon sludge coating the inside. This effectively reducing the area of the intake by about 30% I would guess. Spat the dummy over it and blanked the thing off completely. Will just live with the emissions light for a while and see how it performs. It really is a bad idea to make an engine eat its own waste.
  4. #324
    Aug 2011
    Lake Macquarie
    Will probably use more fuel with the egr blanked off.
    I just had my 2nd egr valve **** itself so I got the egr deleted so no more CEL and I have been averaging between 600 to 650 klm's to a tank.
    Use to average 800 to 850.
    I'm getting the delete removed, getting a new egr and fitting a provent.
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
  5. #325
    Jan 2008
    Sunshine Coast
    Guys a physical blank of the EGR, throws out the DPF soot calculations and it will start regenning more frequently, it defaults to a km based regen rather than when it actually needs it, wasting fuel and forever cooking the engine bay. Either delete it with proper software, or fit a Provent and just live with the EGR part like I currently do.
    And ALL current diesels suffer with EGR / oil blowby buildup, stalling and burning out EGR motors, including Volvo, had a long chat with a disheartened XC70 bloke last week.
  6. #326
    Feb 2014
    Central Vic
    The fact that the 189 only requires a 20min 'fix' says to me it's about programming the EGR valve to revert to a more normal active state ......to me, that's the last thing you'd want.
  7. #327
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Greg Roles View Post
    I don't think either asa572 or Johnnojack have DPFs in their TDi's
    Resident grumpy old fart
  8. #328
    Jan 2011
    Adelaide SA
    Correct kaanage, no DPF in our 2005 1.9 TDI
    "And ALL current diesels suffer with EGR / oil blowby buildup, stalling and burning out EGR motors, including Volvo, had a long chat with a disheartened XC70 bloke last week."
    It's like, if you want to have a diesel here is a big anchor, you have to tow it around and maintain it. Yet the dealers will say "what anchor".
  9. #329
    Feb 2014
    Central Vic
    Diesels are for towing type work; not for economy unless you 'get out' early and until the public finally works it out.....or they're legislated out of existence.
  10. #330
    Apr 2009
    Berwick, Victoria
    Hi Greg,
    I have a Mk5 TDI GT.
    Years ago I had a DPF failure (under Warranty) VW refused to come good, Consumable item and all that Bull****. So I chose to fix it myself, consisting of. Millteck performance exhaust with delete option. Fitted a bypass on shutdown valve and blocked off all EGR. Earlier I also fitted a Catch-Can as I too noticed in short KM's build up of soot/gunk in the inlet tract. For EGR, I fitted blank-off plates, removed pipe, etc and of course finished it with an ECU Tune.......Best thing I ever did.........Now the car does take longer to warm. But I also have more HP with better sound and even economy. With tune software, it was manipulated to ignore EGR and to date no problems. No warning lights, no regen, etc. Car runs better, more derivable with power. Great economy 800 to 900 Km per tank around suburban Melbourne. I have had other electrical gremlins but not related to this.....Previously bad soot or smoke in exhaust due to DPF failure. Now only smoke under certain power conditions only but much, much, much less. Overall I am producing less pollution (no smoke) while using less fuel. Simply put, better, better, better. The guy who done my tune (no names) You know him. he is/was in QLD. Doing these tunes for the exhaust upgrade. Overall not cheep but well worth it especially when compared to a replacement DPF and the VW emissions issue.
