Page 32 of 35 FirstFirst ... 223031323334 ... LastLast
Results 311 to 320 of 341
Thread: EGR should we all be more concerned
  1. #311
    May 2012
    EdenHillsSA
    Quite an impressive collection of the automobiles you have there.
    It must be the recall for the EGR in your T5.
    Yes - as I stated, it's for the EGR, but do you have any idea what the recall's about ... ie why it is necessary?
    2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
  2. #312
    May 2012
    EdenHillsSA
    Quote Originally Posted by greymad View Post
    Well, here I am answering(?) my own post.
    The best I could get out of the collar & tie on the front desk is that the EGR valve spindle (or whatever its real title is) tends to stick.
    Not good.
    I asked - "will the replacement unit do the same?"
    ...Of course not, sir.
    Yeah, right.
  3. #313
    Adelaide hills, SA
    Of course it will, when it gets older (used). Cleaning the t/b as a part of your 30,000km service should prevent that. Do nothing and you will have one expensive part to replace down the track.
  4. #314
    May 2012
    EdenHillsSA
    Well what is confusing here for me is that this work (whatever it really was) was carried out within 2000km's of the vehicle's first (15,000k) service.
    If the "cleaning" is a regular requirement then it should have been done at 15k.
    And how long does cleaning an EGR take anyway ... they had the car for a day and a half. At least I got a loan car (even if it was a crappy well-used Caddy).
  5. #315
    Jan 2011
    Adelaide SA
    Update. Clouds of black smoke under hard takeoffs again. Only about about 20000ks since all was cleaned. Has had a restrictor in EGR cooler intake flange with a 10mm hole in it. Took it out yesterday and put in one with a 5.5mm hole. No fault code came up, so probably should have experimented a bit last time. I guess I will still have to make some some time to clean things up again and check the EGR valve is not leaking or jamming. Bloody thing.
  6. #316
    Jan 2011
    Adelaide SA
    Yesterday when driving on the freeway ENGINE EMISSIONS code came up, for first time. Then went away. Should I worry about it or continue to ignore it?
  7. #317
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by Johnnojack View Post
    That would be due to the car registering too little EGR I reckon, 7mm seems to be the minimum hole size of choice.
    Its just an annoying light, nothing to do with fuelling etc, I drove with that on and off for years.
  8. #318
    Jul 2011
    Canberra,ACT
    Can some help with the location of the EGR in my 6r polo TDI and can a blank it off?
  9. #319
    Jan 2008
    Sunshine Coast
    Sure, but you will then be stuck with errors and a permanent dash error light. EGR cannot be blanked totally off on most current cars, even via a tune, only reduced. Most current cars must see at least some EGR, and a final kicker is blanking it off messes up your DPF regen cycle.
  10. #320
    Jan 2011
    Adelaide SA
    Since blanking off a greater proportion of EGR the engine seems to be idling faster, (1000rpm) I think it used to be about 900rpm. (1.9TDI)
    Are the two related?
