Well that's nice to hear, sorry if I was abrupt, but I agree no one likes following a belching diesel, and that fact alone prevents me from going the full removal. Gutting the DPF would be just as bad really, which is why I think partial flow is the best compromise, and whilst it will still soot a bit, it is supposedly at least 50% as good as a 90% OEM DPF. You can also dial in more % removal in the partial flow by increasing the surface area. I'm keen to try and make this work, and balance soot with flow, enough to turn off the regens with the CCode delete tune, but with a form of DPF still in place.
Believe me I've been on both sides of that fence, having bought one of the 3 first Miltek delete pipes to hit Australia, but I have to take note of Gale Banks example that you can indeed build power without soot. Dropping the EGR will only decrease the soot, as too will keeping that inlet air as cool as possible.
I'm quite confident a plate with a small 10mm hole drilled in it, coupled with an O2 sensor spacer would probably not throw a dash cell, yet reduce the EGR dramatically. Whilst my TDI does take longer to warm up, if you drive it normally it's not that much longer, and I'd swap the potential for higher cylinder wear ( already very low in diesels ) with no gunk at all going through my engine, and less soot production. With a tune you would have to watch EGT's very closely, as reducing EGR theoretically raises them.
