Page 18 of 35 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 341
Thread: EGR should we all be more concerned
  1. #171
    Dec 2008
    NSW Sydney
    Quote Originally Posted by Ivo View Post
    What are the chemical cleaning options available to clean the intake manifold and egr when still on the car? I dont want to dismantle the intake system and turbo. Just want to spray something in and clean most of the junk out including the soot buildup on the variable vanes of the turbo.
    Does the Interject stuff work? Is the Wynns stuff available here?
    I don't think it's possible without dismantling. All chemical additives might clean injectors, but the issue is with exhaust system and the additives will be burned out before getting there...
    2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
  2. #172
    Aug 2009
    Before you buy it, ask them if their catch can has a safety valve, it is important so you don't risk the blowing your engine's oil seals.
    I looked at the pictures on their site and it doesn't look like it has and it's not as well made like the provent. IMO.
    Hi guys, new to Diesel, wondering who you suggest for a catch-can? Also have no idea how to fit, so will need it fitted as well.
    Micky
  3. #173
    Jan 2008
    Sunshine Coast
    we need a provent / catchcan sticky. Mods??
  4. #174
    Gosford Central Coast NSW
    is it in this thread... its in yours cog?
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  5. #175
    Adelaide hills, SA
    Quote Originally Posted by cogdoc View Post
    Here is the link.
    http://www.vwwatercooled.org.au/newf...&postcount=140
    Do write up on your installation onto your GT TDI and I'm sure it gets sticked.
  6. #176
    Jan 2008
    Sunshine Coast
    Post 2 I wrote a bit on mine, but there's a great link back to TDI club.
    http://www.vwwatercooled.org.au/newf...ad.php?t=13929
  7. #177
    Jan 2008
    Sunshine Coast
    I'm about to help Larry put a Provent in his glorious TDI, so I'll do a picture shoot and writeup. Looking forward to doing it a second time, this time I know what to expect and can do a serious job of it.
  8. #178
    Nov 2009
    Brisbane, Queensland
    Stopping EGR
    Hi,
    I've read through all of this post, and numerous others but I'm still uncertain about whether I can remove the EGR valve in my 2L TDI Golf (2005...so it's the 103kW PD engine without a DPF).
    1) Can I replace the EGR valve with one of these straight through pipes (that still have the vacuum hose attachment on the side, and leave the intake flap manifold flap in there):
    HTML Code:
    http://www.egrvalve.co.uk/index.php?page=home
    Or will this throw up codes about low EGR flow? Where would those sensors be that detect that low flow, because there is only a vacuum attachment (no electrics) going to the unit I would be removing?
    So I'm not talking about just blanking the EGR pipe off, but rather blanking it off and installing a straight-through pipe as well.
    Is this going to be a problem on the 103kw PD engines? Some say yes and others so no!!
    Thanks,
    Tony
  9. #179
    Jan 2008
    Sunshine Coast
    Error codes for certain. The O2 sensor in the exhaust will read too much O2 and freak out. You need a "wayne angle block" from VW vortex, or a way to simply space the lambda probe out of the direct exhaust flow. I've heard spark plug spacers work the same. I just got an angle block, it hasn't gone on yet, but the guys in the US have worked out this angled metal block does the trick, and then you can then block off the EGR.
    Downside is the 103kw has less heat handling ability than the 125kw, and the turbo's on the 103 have been self destructing due to too high exhaust temps after chipping. Removal of the EGR will give higher EGT's and you at LEAST need a EGT gauge to watch this temp, as anything over 650-700 degrees is considered terminal to turbo's by all the yanks in the know. I've seen 800 degree spikes in my stock 125 which is temporarily into the danger zone.
    Few things to consider my friend!
  10. #180
    Oct 2006
    42draft design sell one too which looks a bit nicer in my mind. didnt know that they were using them for the diesels, they are popular on the petrols since they run a pre cat o2 and post cat o2 and a high flow cat disrupts the second o2's reading. anyway back on topic....
