Results 1 to 3 of 3
Thread: early diesel head
    Apr 2006
    sydney australia
    early diesel head
    Does an early diesel cylinder head have combustion chambers machined into them?
    Apr 2006
    Hobart,Tas
    No, definately not.
    brackie Guest
    Flathead
    Like most diesel heads the 1.5D head is flat with only a small combustion space in the top of the piston. This is there more to provide clearance for the valves than space for combustion. Some direct injection diesels have a larger chamber in the piston crown.The 1.5D has precombustion chambers that provide not only the "swirl" needed for efficient distribution of the diesel mist from the injectors but also enough volume to allow for the heated air/fuel mix to ignite. This makes for a "softer" ignition that on older engines enables the precombustion chamber diesels to run more quietly than direct injection diesels. That all seems to have changed with the VW direct injection motors
Similar Threads
  1. question about head gaskets for early 1.5D
    By posscakes in forum Diesels
    Last Post: 14-05-2006, 02:47 PM
  2. Head gaskets and rings
    By hiho in forum Diesels
    Last Post: 05-05-2006, 07:04 AM
  3. rebuilt diesel cylinder head on ebay.
    By Golf Loon in forum Diesels
    Last Post: 22-08-2005, 09:38 AM
