The core would not pull out like that as it is a snug fit, so I had to open the case further.
This allowed me to remove the core, and the very delicate heat sheld, which despite your best efforts will likely fall apart. Mine broke into a few pieces by reassembly time, but I put them back in as best I could, this helps keep the heat in during regens, and you want this core to always be as hot as possible. Also very important to mark which side is the top or inlet, as you want to reverse flush the core. There are arrows on the side showing flow, but they are quite faint.
