Originally Posted by
Harpo
So in hindsight when buying a second hand diesel car with DPF should use diagnostic equipment to check out clogging to avoid a time bomb OR go for GTI ( non DPF) not GT as fuel consumption and torque is improving eg MK7 GTI
You cannot compare a GT to a GTI, two completely different cars with completely different engines. You are right though that a buyer needs to do some investigation when buying a modern Diesel as most if not all of them now have a DPF so eventually all of them will have issues for potential buyers with clogging - having said that its not like there's no issues with a modern Petrol either , the GTi has a lot of common problems for potential buyers too - the important part is that there are solutions to the problem. The washout you performed seems to have worked for Greg, the Moly treatment did wonders for me and for others a DPF delete has been highly successful but remember that a DPF delete is illegal and comes with some very heft fines if caught so if you do go down that path my suggestion is keep it to yourself and don't go posting it on the forums.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
