What a nightmare, but yes I am afraid the DPF has always been considered a consumable, for they know it will clog up eventually.
I'm also afraid your upgrade options are rather limited, you can delete the DPF with a tune to suit, but that's both highly illegal and no guarantee to fix the situation, in fact a DPF of any sort should be reducing the smoke! I have seen DPFs on eBay over in Europe area for several hundred delivered, but I guess it's obvious you want to try and find out what's causing this in the first place. If the DPF is showing normal parameters, that is the correct pressure before and after, then the one that is there is very likely fine, it's just so odd to be getting anything post DPF, it's a complete interference style filter.
I wonder if you have an oil leak somewhere such as a turbo seal, is the car using oil? Also wonder if a injector has gone or is playing up and over delivering fuel, is it thirsty?? Anything else odd apart from this friggen smoke nightmare???
