OK, here's the info in the service bulletin about Active regeneration:
Lasts about 10 mins.
designed to heat the rear of the DPF up to 600-650 degrees.
The DPF has more platinum in the front over the back. The front runs hotter and this is where the passive, all day soot burn off occurs. When the colder rearward part blocks up, active regeneration occurs.
Exhaust gas recirculation is switched off to raise compustion temps
Extended injection of fuel occurs, with a secondary, smaller late injection to raise exhaust gas temps
Supply of intake air is adjusted with the electric "throttle" flap
Charge pressure is adapted (raised) so the driver feels no difference in power or driving
Also an interesting page on "over-run" operation in urban traffic.
In heavy traffic with strong changes in load, particular measures are required to maintain cleansing of the DPF. Normally no fuel is injected on over-run, but then the exhaust temps drop, and the DPF isn't regenerating.
If the car decides there is too much over-run happening:
A small amount of fuel is injected at over-run, approx 35 degrees after TDC
Since there is no main injection at TDC, there is no combustion and this extra fuel vaporises
This fuel then combusts in the DPF, and heat generated continues the regeneration cycle
The temp sender after the DPF controlls this process.
So it seems if you are a urban traffic driving rev head ( ie Mischa ) then the poor car will be doing this every time you back off the throttle at 4500rpms.
Perhaps this is why the lil wippersnapper had problems with his DPF early on.
I know I flog my car, but I stay between 2 and 4000 where the action is.
