Originally Posted by
Russ59
..... and when I went to take off it wouldn't rev and stalled. I had my foot on the clutch and when I tried to start the car it was dead ( lights were on but nothing happened when I turned the key) nearly ended up with a Rav 4 up my ar$3. I turned the key off and then back on again, it started
Russ,
I can't help you with your rough running problems, as I haven't experienced anything like it. My Transporter has a DPF, but as it does nearly 100% highway driving, it has probably never needed to "regenerate".
I can say that what happened when you stalled your engine is 100% as intended by VW. You must switch it off completely before you can operate the starter motor again. Just to hazard a guess it is to stop people trying to run the starter motor when the engine is already running (as if anyone could NOT notice that their TDI was already running ). IIRC it is detailed somewhere in the owner's manual.
