Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: DPF regeneration..according to Audi
    Jan 2008
    Sunshine Coast
    Found this today on the AU Audi site. Last part mentions active regen as often as each 1000k! I've noticed the higher idle around 1000rpm several times now, and I assume this is indeed the active regeneration cycle. Need to get me EGR hooked up to be sure.
    cut-------
    A diesel particulate filter is a system for removing diesel particulates from diesel exhaust. Audi uses a system that exploits the most advanced state of the art: the "catalysed soot filter" (CSF for short) has a filter coating containing precious metals which acts in two ways. The passive regeneration process involves the slow, environment-protecting conversion of the particulates deposited in the catalytic converter into CO2. This process takes place within a temperature range of 350 - 500 degrees and occurs continuously without any special measures being required, predominantly when the car is being driven at motorway speeds.
    Only if the car is used for any length of time at low loads, for instance in urban traffic, is the temperature of the exhaust gas actively raised to around 600 degrees every 1,000 to 1,200 kilometres, to prompt additional regeneration of the filter. The particulates captured in the filter burn off at this temperature.
    Gosford Central Coast NSW
    hypothesis:
    so from what i can gather, the dpf works like a slow combustion stove.... trapping the soot (carbon) and allowing it to burn inside the dpf to form C02. since diesels pump plenty of excess oxygen under normal consitions, theres plenty in the exhaust to support this combustion process.
    as you block up the system, i would guess that exhaust pressure sensors on either side of the dpf indicate that "regeneration" or more accurately 'burn off' is required. i would guess that then the ecu adjusts the fuel maps to run excessive boost, thereby supplying extra 02 to pass through the exhaust system and aid to burn the built up carbon.
    remembering that with a diesel, power output is a function of how much fuel you are able to burn in a stroke, NOT dependant on boost pressure, per-say. the burn off phase would equate to a "lean" running condition, not really applicable to diesels, buth the analogy stands.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Logzy Guest
    Quote Originally Posted by cogdoc View Post
    +1 .
    Jun 2008
    South Coast N.S.W.
    Anyone happen to know what would happen if the car decides to do this whilst still not at operating temperature ?? I had an incident with mine today where I had driven around 70 km's turned the car off and returned a couple of hours later. I started the car as normal but it appeared to be running a bit a rough and I was having to rev it more than usual to take off. I had to stop and start at a few sets of traffic lights on a couple of hills and it didn't like it very much and appeared to a bit jerky on take off, I then had to stop at another set of lights and it was at that stage idling at 1000 rpm (200 rpm higher than usual) it was still not quite at operating temperature and when I went to take off it wouldn't rev and stalled. I had my foot on the clutch and when I tried to start the car it was dead ( lights were on but nothing happened when I turned the key) nearly ended up with a Rav 4 up my ar$3. I turned the key off and then back on again, it started and I drove off again having to use more accelerator than usual as it wasn't running right. I stopped a few k's along when I could get off the road and it was still idling at 1000 rpm and was jerky on take off and still needing a bit more throttle than usual. By the time I got another couple of K's along the idle had dropped to normal again but the car was still feeling jerky especially when backing off the throttle and slowing down through the gears.
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    Dec 2007
    Quote Originally Posted by Russ59 View Post
    Russ
    I think you have a different problem.
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
    Dec 2007
    Mostly correct, but I believe the extra heat is created in the exhaust by supplying MORE fuel, not less.
    Diesels are highly sensitive to overfuelling, to the extent that pistons will burn if overfuelling is consistent, such as you might get in a poorly tuned Cruiser diesel with aftermarket turbo.
    Jan 2008
    Sunshine Coast
    I've a whole tech bulletin on it, and I do seem to recall something about late injected fuel timing so it ignites in the DPF, thus heating it up to burn off the extra soot. Can't be @rsed looking right now sorry!
    VW also mention that the DPF will progressively get blocked from the rear forwards, so it's a throw away item at some stage. I doubt it will be a cheap part!
    Russ, that sounds exactly like the regen cycle, everything but the jerkyness / lack of power. I've turned the car off mid DPF regen before, and found it wants to do the typical 10 mins regen cycle all over again on hot restart, but I've yet to do a cold start, where I do assume it would do the same thing.
    I've found that apart from the increased idle, the car still drives as per normal, and still goes like the clappers if you up it. When it's hot anyhow!
    I would guess that a regen / late injection cycle on a cold start could make the car run poorly, so let us know if it's back to normal tomorrow.
    You always have to turn the key all the way off to restart it too mate, quite embarassing to stall it in peakhour, but I think all us manual oilers have been there...several times
    Jun 2008
    South Coast N.S.W.
    Hey Greg,
    I sent an email through tonight to the salesman and have asked him to forward on the details of the symptoms to the service dept. for me and ask them if they have any idea on the cause. I am guessing from what I have read about the DPF regeneration cycle that it may be responsible for what I experienced cause I'm pretty sure it wasn't my driving as I am used to the clutch now and having to give it a few revs to take off. I'll keep you all posted !!
    Russ
    Russ
    Canberra
    ..... and when I went to take off it wouldn't rev and stalled. I had my foot on the clutch and when I tried to start the car it was dead ( lights were on but nothing happened when I turned the key) nearly ended up with a Rav 4 up my ar$3. I turned the key off and then back on again, it started
    Russ,
    I can't help you with your rough running problems, as I haven't experienced anything like it. My Transporter has a DPF, but as it does nearly 100% highway driving, it has probably never needed to "regenerate".
    I can say that what happened when you stalled your engine is 100% as intended by VW. You must switch it off completely before you can operate the starter motor again. Just to hazard a guess it is to stop people trying to run the starter motor when the engine is already running (as if anyone could NOT notice that their TDI was already running ). IIRC it is detailed somewhere in the owner's manual.
    Jan 2008
    Sunshine Coast
    I'd have to second that, as I'm finding blasting around in the city my diesel is regenerating every few weeks.
    Russ, good luck mate, and if your car continues to run rough you could always consider unhooking the battery for a good hour and seeing if this defaults the car back to zero....then again i guess the DPF will still be sending pressure differences and wanting to start a recycle if it is indeed blocked, and it'll happen all over again!
    Anyone near you have a vag com to check for error codes?
    Anyone??
