Results 1 to 10 of 16
Thread: DPF regeneration
    Nov 2014
    Narwee, NSW
    DPF regeneration
    DPF load is 100.6%.
    Should I enable regeneration by entering code 21295?
    The car may burn down when regenerating with dpf load over 90%.
    Thanks guys.
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by snake View Post
    DPF load is 100.6%.
    Thanks guys.
    Car should have stopped driving completely at 90%. Has it been in limp for a while now??
    Never, ever heard of this, and yep, highly likely you will catch fire if that is somehow correct.
    Nov 2014
    Narwee, NSW
    Today I took the car down M5 motoway and carried out a force regeneration. It was successfully cleared the DPF. Started with load 100.6% after 15 mins it was down to 3%. No more limp mode. The warning lights stayed on until I cleared the faults.
    Happy days.
    Thanks for the help and advice.
    Mar 2013
    Brisbane QLD
    At that % it should not have even allowed you to do a DPF burn....Usually if the % is too high then its says it cant be done. The only way I know is to tell the car that a new DPF has been fitted, that Allows the ECU to see zero grams etc and allows the burn at your own risk if fire in the hole!
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Nov 2014
    Narwee, NSW
    Refer to the below link.
    Forcing DPF regens with Ross Tech VCDS
    Jan 2008
    Sunshine Coast
    My question is what are you reading it with, sounds like it was only actually at 60ish percent, for that is where you can force a regen and lights go out. At 80 the car cuts boost and you are in low boost limp, at 90% the car won't let you start it as far as I know, never gotten that far.
    Just FYI for anyone reading this in future, anything beyond 90% is an absolute fire hazard.
    Apr 2009
    Gippsland Victoria
    Quote Originally Posted by Greg Roles View Post
    Haha, last service I had the guys scan and was 85%!.Sent them your DPf removal and clean thread(with photos) for next service which is in 6 weeks. Always liked the Fantastic 4 perhaps i'l be emulating the "Human Torch" in the interim!?
    Current:12 Golf GTD, Mods on order -Bluefin Remap, Mods planned-plenty
    Former:08 GT Sport TDI DSG Bluefin, HPA SHS Coilovers,H&R Swaybars with Whiteline Adj Links
    Melbourne, Vic
    Quote Originally Posted by stormshark View Post
    You must have a dodgy sensor then. I was going into limp mode when DPF was 55%. Annoying as hell. As soon as you saw the light, you had about 20km to run a regen or limp mode it was. Then 2 weeks later, same thing again. Replaced both DPF sensors 3 years ago, and only had light come on twice, and never a limp mode again.
    I would suggest that you get the sensors checked if you get high % readings like that. And maybe some Penrite DPF cleaner.
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
    Apr 2009
    Gippsland Victoria
    Quote Originally Posted by spud75 View Post
    The cars done 206k so probably getting up there, I use the Cleen diesel products on the car which seem pretty good but thanks for recco.
    Feb 2014
    Central Vic
    Any chance an additive may actually be causing it?.
    Was it dealer or ,say, Penrite approved?.
