Originally Posted by
Transporter
Greg, there is no "B" revision sensor. The "B" means you're looking at the DPF sensor for usually 4 cyl. VAG engines, which has the voltage output approx. 1V at 0 pressure. The DPF sensor which p/n ends with the letter "A" has the output voltage 0.5 at 0 pressure.
There is an aftermarket sensor from BOSCH for your Yeti, which I use instead of the genuine one, it fits all VAG 4 cyl. TDIs.
What would be normal regen cycles? Now i am getting every 1000 km regen....no dash light, just rpm increase a bit and cat losing speed...
Regards
Sent from my D6503 using Tapatalk
2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
