Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: DPF blues
    Jul 2010
    Melb
    DPF blues
    After almost 2 years with our MkVI tdi golf wagon, my wife is basically ready to throw in the towel.
    She wants reliable, and we obviously don't do enough open road driving for the tdi with a DPF to clear itself. The regens are getting more common, and the way it drives through them is awful, stalling, lurching - less than ideal.
    As it stands she won't accept a less than legal fix (dpf delete). So unless there is a practicable solution elsewhere I can see we are going to have to move beyond the tdi and presumably get the tsi version.
    I think I know the answer, but is there a ready fix for the tdi beyond the delete?
    And is the there anything wrong with moving to the 118tsi? And will they last?
    We actually want a car to last for 10 years, it's what we've done in the past & hope at least to do in future - i.e we don't feel the need to change up. We just want a good reliable car for years to come.
    Adelaide hills, SA
    Did you take it to your dealer?
    Maybe you have faulty DPF Pressure Sensor, it's a very common fault.
    I'd like to also keep our TDI Tiguan for 10 years and am confident that the DPF will go the distance, despite only city driving.
    Jul 2010
    Melb
    We haven't had the car serviced by the dealer, rather have used J & F MOTORS in Richmond Vic. It was recently serviced, but not sure if that was checked.
    Is there a reason to go with the dealer for this query, or should I put it to J & F MOTORS?
    My wife has booked the car in with them for this week to have them do a forced regen from the sounds of the conversation she had with them. Do I take it that I should get the pressure sensor checked prior to any forced regen?
    Thanks
    Dec 2009
    Melb. (SE), VIC
    How do you force a regen? Drive on a freeway at like 4k rpm?
    Adelaide hills, SA
    For that you need VCDS or similar. The instructions are at Ross-tech.
    Adelaide hills, SA
    Quote Originally Posted by GolfWagon View Post
    Thanks
    Yes, the pressure sensor has to be good in order to do a successful regeneration.
    Dec 2008
    Sydney/Canberra
    Is your preferred workshop using the correct engine oil?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2009
    The Euro 5 standard (01/09/2009 onwards) has stricter durability requirements for emissions devices, which has been increased to 160 000 km (up from 100 000 km for Euro 4 and 80 000 km for Euro 3).
    In VW's European service schedule, the DPF in a Golf is to be checked at 150 000 km or 180 000 km (depending on the model year) and then every 30 000 km thereafter.
    You can use this information as a general guide to the expected lifetimes of emissions devices when choosing your next car.
    Quote Originally Posted by getjet View Post
    Vehicle speed: 60 km/h or above, held constant.
    Engine speed: between 1800 and 2500 RPM.
    Gear: 4th or 5th (manual) or sport mode (automatic).
    Duration: 15 minutes, or until the DPF warning light goes out.
    Quote Originally Posted by Umai Naa!! View Post
    J&F Motors is quite a reputable workshop, I dare say they'd be using the correct oil!
    Good luck with it.
    Dec 2008
    Sydney/Canberra
    I've heard the same thing about other 'reputable workshops', who may or may not be sponsors of this very site.
    But that's a matter for the individuals involved to chase up.
    Anyways, modern diesel cars aren't for everyone. The salesman wont go down this path though, as theyd potentially miss out on a sale.
    '01 Beetle 2.0
