Originally Posted by
250 downunder
Hard to see how push or tow starting could cause a timing belt to slip. The only load on the timing belt is that caused by the camshaft, and that load will not change however the engine is turned.
Please correct me if I am wrong.
if the cam timing is off the valves will hit the pistons.
it is however likely that if your ttrying to tow start a car that you've had the engine apart and you know this, so you're likely to have checked by turning over the engine by hand and thus are confident that roll starting will be OK
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
