Thats funny, on frosty mornings when im not on a hill thats steep enough for roll start I use ether
As Greg said.
You really should start up and get moving (30s idle max.), warming the engine by gentle driving (and not just the engine, the whole drive train). The reason for this is to get the engine at the operating temperature ASAP. The cold engine is running richer mixtures which contribute to acid formation from unburned fuel, which etches the cylinder walls and pollute the oil in the sump, so you want to shorten that time. That's what wears out the engine most.
Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
I'll go give a roll start a crack now - wish me luck!
