Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Dismal DPF!
    May 2012
    Toowoomba, QLD
    Dismal DPF!
    Just wondering if anyone has encountered issues with DPF Regen in POLO 66TDI's?
    I have had to clean the DPF multiple times (sometimes within a few days), but only have 7k or so on the clock.
    The car gets its usual long trip, as requested in the manual. But i seem to be doing this more then i thought i would have to. I was buying Diesel from 7-11 originally, and through some research discovered that i needed to be quite particular with my fuel selection, considering the DPF. I am now fueling up with BP. The problem seems to have improved a tad.
    Considering i am new to driving Volkswagens, a Diesel, and only discovered the DPF after my purchase, i am just a little concerned if this is the norm or not?
    Oct 2010
    Melbourne, VIC
    There's been some discussion about this in the Polo 6R forum but it seems to have been a bigger problem in the UK (and possibly the European mainland) where there have been many complaints about the rough running and poor economy due to the frequent regens. The lack of really low (just off idle) torque in the 6R TDi compared with older diesels seems to me to be an attempt by VW to force drivers to use higher rpm, which should reduce soot levels, in order to protect the DPF.
    Resident grumpy old fart
    May 2012
    Toowoomba, QLD
    Thanks Kaanage. I will suss out some of those threads and see if i can find some more info.
    Just seems bizarre to be doing such regular regens of the DPF when i have barely put any kms on the clock. I feel as though i am following what is suggested in the manual to the tee, but still feel as though something is up. The fact that i have also read people clocking up 60,000 before having to do there first regen is also making me believe something is up.
    Asked some questions at my local Dealership, and got the typical "watch where you fuel up", and "watch your driving style". Didn't seem interested at all.
    Could it maybe be a dodgy sensor? ECU upgrade required or something?
    Adelaide hills, SA
    Get the DPF pressure sensor checked.
    May 2012
    Toowoomba, QLD
    Is that sensor a known trouble maker?
    Adelaide hills, SA
    Yes it is. Especially the earlier one were.
    May 2012
    Toowoomba, QLD
    Any idea on what they are worth? If in fact i do need a replacement?
    Jan 2012
    Just wondering, how bad was your economy? When I had mine I had about 9L/100km on highway and about 11-12L/100km. IMO that's pretty bad for a diesel, considering my Citroen DS3 gets about 8-9L/100km even with its rev-happy 1.6 petrol engine and rather ancient 4-speed slushbox.
    I was also advised to get the DPF sensor looked at too.
    TRADED THE BEE'12 Sport Yellow/Black Citroen DS3 DSport THP155 6-spd manual w/ tech pack.
    SOLD '18 BMW 125i M-Sport | Sunset Orange | Sunroof | ZF 8-spd auto
    '23 MINI Countryman SE ALL4 PHEV | MINI Yours | BRG
    Dec 2008
    Sydney/Canberra
    Given the issues they're having, I wouldn't be surprised if there's a campaign in the works to have the ECU re-flashed.
    They'd want to do something about it, because a forced regeneration usually takes around an hour to do, out on the open road.
    One thing we did notice from customers' comments was that it could be related to drastic changes in driving habbits. Ie, going from regular long distance runs to a few days of stop/start driving. Perhaps the whole shooting match isn't coping?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2010
    Quote Originally Posted by Grizzy View Post
    They are around $100 from a dealer. Cheaper online. I'm assuming its the same part on the Polo.
    Have a search for it, old part number is 03G 906 051A, new number 076 906 051A.
    More info and pictures here - http://www.vwwatercooled.org.au/foru...igh-62596.html
    Golf GT Sport TDI
