Yep this particular model seems to cop the worst DPF problems. Things to help are to use good fuel from the top three brands, avoid short runs, use Morleys smoke killer, and install a Provent if you can squeeze it in somewhere! If any of you guys are in Brisbane, I want to have a good look at one of these once Carformance is set up properly around July. Like to work on fitting a catch can, and do some testing on the DPF setup. They sure seem to suffer more that they should.
My gut feel is the DPF is either too small, or too far removed and not getting hot enough passively.
Oh and those differential pressure valves are dodgy at best.....They do need to be calibrated once fitted in Vag Com chaps under advanced coding.
2015 Polo Comfortline 6M + Driving Comfort Package
2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
(2008 MY09 Polo 9N3 TDI retired hurt hail damage)
The old DPF light came on again over the weekend. I seem to be getting used to seeing it. So i took the car for a nice long trip to give the DPF a clean out as usual. The light disappeared after 10mins of driving at 80+ kms, so i proceeded to travel home. This got me thinking about my driving habits over the past few weeks. My driving over the last few weeks is as follows:
• 2 weeks ago = DPF light comes on. Take the car for a long trip to burn the ash off.
• 3 days later = DPF light comes on again. So i take the POLO for another long trip. DPF light disappears.
• 5 days of 15-20 minute trips to work. Inner city driving.
• 2 days of highway driving. Few hours long, per trip.
• 5 days of 15-20 minute trips to work. Inner city driving again.
• Weekend just gone = DPF light has come back on!
Surely i have done enough driving (80+ kph) to justify the DPF regen over the course of a few weeks?
With only 7,499kms on the clock, this is getting ridiculous! I plan on going to the Dealership this afternoon and start asking some GOD DAMN QUESTIONS!![]()
When doing the 80km/h+ runs, are you also driving at 3000rpm+ to help the soot burn out (the ash stays as the residue)
Resident grumpy old fart
Our dealer told us that if the DPF was clogged and we brought it in, they'd basically drive it at about 4000rpm on the freeway for about 1/2 an hour![]()
good old italian tunes keep diesels alive sometimes .. I have replaced the rear end of my exhaust .. and the note is noticeably different after i have "cleaned out" the dpf lol
mk6 TDi - DSG -VIEZU tuned- Carbonio . Whiteline RSB/Neuspeed FSB . Golf R interior . Defi boost . Twin 4" Magnaflow tips . GTI shocks & springs
