Yep this particular model seems to cop the worst DPF problems. Things to help are to use good fuel from the top three brands, avoid short runs, use Morleys smoke killer, and install a Provent if you can squeeze it in somewhere! If any of you guys are in Brisbane, I want to have a good look at one of these once Carformance is set up properly around July. Like to work on fitting a catch can, and do some testing on the DPF setup. They sure seem to suffer more that they should.
My gut feel is the DPF is either too small, or too far removed and not getting hot enough passively.
Oh and those differential pressure valves are dodgy at best.....They do need to be calibrated once fitted in Vag Com chaps under advanced coding.
