My economy is around those figures also, and lets face it, they are not great. The reason i haven't been too concerned with the economy as yet, is im getting more bang for my buck then i was with my previous vehicle (dodgy Nissan). So im saving money, but maybe not as much as i should be?
Did you manage to get your DPF sensor looked at? When you were advised?
Is an ECU re-flash an upgrade? Or just a reinstall?
Yeah the regen is a pain in the arse. Wasting time and dollars just to burn the soot off.
I think i fall into the bracket of 'stop-start' and 'long distance' in the space of a week........hhhmmmmm
---------- Post added at 10:40 AM ---------- Previous post was at 10:39 AM ----------
Thanks mate. I will look into this!
---------- Post added at 10:41 AM ---------- Previous post was at 10:40 AM ----------
Cheers!
Resident grumpy old fart
I am about 10 minutes away from going for a drive. I think this calls for some research!
Will update you all with some figures when i get back
---------- Post added at 01:56 PM ---------- Previous post was at 12:52 PM ----------
Alright, test results are in.
So from the get go economy was averaging around 10L/100km around town. Then after fiddling around with the Combi Instrument's OK/RESET button (thus resetting the counter), the figures dropped to around 6.5L/100km. Which are figures i expect from the 66TDI. Im guessing highway driving would be about 3/4's worth of that?
Are the figures i was presented with at the start an accumulation of averages from the day i bought the car? So all that was required was to reset the counter to get a true reading of my fuel consumption? Or is my Polo suffering from Polio![]()
If the trip is like my Skoda Octavia (expect it is), you have an instant, a short term and a long term fuel use display. Instant changes constantly. Short term is for the current trip only and resets after about 2 hours idle from memory. Long term average is just that, unless you reset it of course.
Your previous figures sounded terrible to me, given my Octy is much bigger and has the old school 1.9 TDI. Long term average is 6.6 comprising vast majority of commuting K's. Suburban trips tend to range from 7.5 down to 5.8 depending on traffic, +1 - 1.5 with AC on. So I would have thought your most recent posted figs are more like it.
On the other hand if you do lots of short trips/heavy traffic it will be bad, like any car. Worst case stuck fast in impossible traffic I have seen north of 30 l/100 on the short term readout. I somehow find that perversely hilarious...
something is definately wrong.
My Mk5 Jetta CR2.0 125TDI is returning 4.5l/100km Highway and about 6-6.5l/100km in the city (13,700km on odo)
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
TRADED THE BEE'12 Sport Yellow/Black Citroen DS3 DSport THP155 6-spd manual w/ tech pack.
SOLD '18 BMW 125i M-Sport | Sunset Orange | Sunroof | ZF 8-spd auto
'23 MINI Countryman SE ALL4 PHEV | MINI Yours | BRG
Yes, but you can also use this to calibrate your MFD by resetting the long term trip computer each time you refill fully and compare the long term MFD consumption reading against actual consumption. Then you can at least have some confidence in the short term readings (and even more in the long term readings).
Grizzy, if you've never reset your long term trip readings and that was what you were reading, then that's still terrible no matter how inaccurate your MFD is (they tend to be about 10% optimistic). If that was your short term reading and you'd driven within the last 2 hours, it's still not a great figure unless you were stuck in bad traffic earlier.
