Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Difficulty starting my TDI
    Adelaide hills, SA
    Good battery should last 4 years at least. It is not unusual for battery to last 7 years in Japanese cars. Even the battery starting diesel engine should last more than 3 years since it has bigger capacity for that.
    If you want your battery to last - put it on the battery charger once a month, since the vehicle's charging system is designed to charge the battery to 80% capacity only.
    http://www.ashdown-ingram.com.au/CA2...+Chargers~&3=~
    Adelaide hills, SA
    Quote Originally Posted by shogun2 View Post
    A battery recharge overnight seems to have done the trick. Now seeing 13.6v on the battery without the ignition on. haven't been able to check the cranking voltage, as I can't see the multimeter and turn the key at the same time.
    13.6 V is surface charge. You need to remove the surface charge first. Turn the head lights on hi-beam to put load on the battery, that will remove surface charge, watch the voltmeter - let the voltage drop below 12.5 V and turn the head lights "off" the voltage should now return to above 12.5V and use table below to check your battery state of charge.
    Open Circuit Voltage Approximate State-of-Charge at 25°C
    12.65V - 100%
    12.45V - 75%
    12.24V - 50%
    12.06V - 25%
    11.89V or less - DISCHARGED
    You can get/make longer leads for your voltmeter. I even thinking about installing voltmeter in my van. Something like digital thermometer with voltmeter from the Jaycar store.
    Jun 2006
    with the dust and flies in western Victoria
    Quote Originally Posted by MRL T5 View Post
    I still have the original battery in our 2001 T4 TDi.......and we replaced the battery in our 2000 Forester just last year.
    I reckon there's something to be said for having as few electrical doodads on your car as possible....
    Adelaide hills, SA
    Quote Originally Posted by Seano View Post
    I do many short trips (like 5km or less with 1 -2 hours brake between trips) and that is what killed my first battery. I didn't use any accesories connected 12V accesories socket during first 3 years.
    I replaced battery in our Forester after 51/2 years and it was still good (preventetive measure) still use it in shed for testing and lighting.
