Do it. Both engines are very strong and you won't damage anything internally from tuning them. The 103 when tuned is very very nice and the gains are a touch larger than you see when tuning the 125's.
You could possibly damage the turbocharger if the tune was over the top but that's about it and as long as you don't go for an internet tune then I'd say you'd be quite safe with any of the places on here.
But are you looking at the more recent common rail versions or the 125 engine with the pump deuce setup which yes has had injector issues. The two are quite different and the common rail engine much less prone to those sort of probs
Just been doing a 'wiki' on VW Diesel engines jeez now I AM confused .....the 103 AND 125 seem to be co-listed ....both 16V CR bore/stroke etc. What's the difference btw it and a BKD engine? Is one a better 'project' engine and why?
Sorry for demonstration of my complete ignorance but v interested.
Yours will be a 103kW/320Nm TDI-CR [common rail, direct injection], engine code CFCH.
The latest one. No injector issues, thats the older model - the BKD (TDI-PD [pumpe-duse])
I have a TDI125 (Octy vRS TDI, engine code CEGA, the stronger version of your engine) and its supposedly pushing out 170kW/450Nm on a stage 2 tune. No issues, feels nice and strong.
Also it could be worth putting your Yeti on a dyno, when I dyno'd my vRS it was pushing out 136kW/361Nm with the stock tune![]()
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
