Diesel Tacho
Hey all,
I heard brackie on the Mk1 forum asking about whether GlDgti had a tacho on his diesel, and i thought that might make for a good thread.
First question: Does anyone have a tacho on their diesel?
I have been thinking about this a bit, and since i'm doing a diesel conversion, and will be keeping the same old dash, i obviously wanted the tacho to work...
So a little bit of thinking later, and i reckon i can do it in one of two ways.
Preamble: The current tacho takes a 12V pulse signal and turns it into a reading on the tacho (unconfirmed)
Solution One (least favourable)- You could mount a small magnet on some rotating part of the car- it only needs to be tiny, so you may not need to worry about balancing, though balancing would be easyby means of simply sticking an equivalent mass on the other side.
Using a sensor called a hall effect sensor, and some pretty simple electronics, one can make it put out a 12V pulse signal whenever the magnet passes the sensor. As i said, this is the least favourable.
Solution two- There is a company that makes a thing called a "tiny tach". It is basically a small tacho which gets its signal by clipping a sensor onto one injector pipe. Unsure as to how they do it, but the problem with this, is it comes with its own digital readout- less than ideal. I want my original tacho to show the signal...
Anyway, what i plan is to get a hold of one of these sensors, hook it up, and work out what signal its putting out, then, hopefully without too much trouble i'll be able to make up a little amplifier circuit, and bob will be my uncle.
Hard to say whether it will work, but i welcome your comments.
Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
1976 LS parts vehicle
Used to have: Mk1 Swallowtail LS DIESEL!
