Results 1 to 10 of 14
Thread: Diesel Performance Filter
    Canberra
    Hey All
    Looking to put a K&N filter into my 06 Golf 2L Diesel. Has anyone done this, and have you had any problems? I looking for slightly improved performance and ecomony, without paying for a ECU upgrade.
    Im also struggling to find the part number, does anyone have this?
    Thanks
    08 POLO TDi.Black.Seat adjusters
    Adelaide hills, SA
    I wouldn't do that, unless I know that the filter I'm installing will catch up the same amount of particles as original one. You may end up with worn out engine sooner and less performance. Also think about the turbocharger as the air that pass the air filter pass MAF sensor and the turbo as well.
    The power gain from air filter replacement is so small you can't even maesure it.
    Use search function you will find too many discussions about K&N.
    Look also in Let the tinkering begin and continue threads.
    Jan 2008
    Sunshine Coast
    Go for it, you'll get a warm and fuzzy feeling, and a cool sticker, but that's about it. The biggest two problems in the stock inlet are the MAF grid, and the 90 degree exit from the top of the airbox just before it.
    Overoiling filters is also lethal for MAF sensors too by the by.
    Jun 2009
    Northfield, Adelaide
    So what do you guys think of BMC filters then?? Or should we steer clear of any kind of Oil based filter?? And what about the CDA version of the BMC filters??
    really unless you're driving on dirt roads most of the time, and you have a cold air induction intake sitting low on the vehicle, how many particles do you think will get past the oil based filters??
    What I think would be a wicked design is the swirl vane intake that causes the heavier dirt particles to get thrown out centrifically, with a small exit duct so the actual dirt particles dont even make it to the air filter. They use this design on some helicopters ( called a scroll case), especially military ones that land in dusty conditions, and they run no air filters before the air enters the engine. They do thousands of hours on those engines before doing overhauls
    I should go read the posts about K&N in here and see if anyone has done side by side comparisons running a standard paper filter on one car and a K&N on the other to really se if the K&N's are really that bad as rumoured??
    Taree NSW
    Quote Originally Posted by dazag View Post
    "Ask and ye shall receive" - an American company Donaldson Filtration [formerly Donaldson Cyclopac] already make this type of unit for agricultural, mining and earthmoving applications. use the following link and scroll down to the "Topspin Precleaner" to view a data sheet:
    http://www.donaldsonfilters.com.au/e...ion/sub16cat16
    They also make a precleaner which ejects dust through the exhaust system called "Donaspin" for engines requiring 350CFM or greater inlet air flow.
    A full product catalogue is available for downloading at the bottom of this webpage.
    Carer for my partner's Eos 2.0 TDI DSG MY09 Candy White/Cornsilk Beige leather trim.
    melbourne
    hey there dazag... i've read enough literature to be convinced that any "cai" attempts for diesels are really just ignoring the fact that the stock intake setup is pretty good as is.
    as for "performance" filters for a diesel- i wouldnt recommend. people have done flow tests and for a minimal (if at all) increase in flow with a bmc or k&n, you're putting a filter in your car that only has a fraction of the filter element that a stock filter has.
    there's no other way around it. if you want a performance increase, then the first stop on the list would have to be a chip. once you've got one you wont be bothering to quibble over what 'performance' filter to place in your airbox.
    Jul 2005
    Newcastle, NSW
    In the time that I have had the modshack on the 2.0TDI I have had better throttle response and a smoother torque/power curve (dyno plots are in another thread). It does not increase power.
    I am not going to say that the filtration is as good, as it probably is not, but I regularly service the car and won't be keeping it past 100K/5 years so longevity is not a problem.
    If you want to try a modshack on your car, I am happy to let you use it for a bit.
    My thread is here on the subject...
    http://vwwatercooled.org.au/newforum...light=modshack
    Jun 2008
    Cronulla, NSW
    Having had my Modshack on for a while, i agree with Mikinoz interms of low down response.
    Trouble i have now is how to clean the bugger. I have the cleaning kit, but just worried about the actual type of K&N filter that sits inside the modshack and wondering how much to oil it. anyone have any clues?
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Jan 2008
    Sunshine Coast
    When you wash it out, it will lose the red colour somewhat. The new oil is tinted red, so just give it a nice even coating, without getting too heavy handed. It's something that's hard to define exactly, but you'll get the hang of it pretty quick.
    Jun 2008
    Cronulla, NSW
    Quote Originally Posted by cogdoc View Post
    ...It's something that's hard to define exactly, but you'll get the hang of it pretty quick.
    yeah, as in i'll find out when i kill/clog the MAF
    Thanks Cogdoc, i'd actually forgotten about the dye in the oil and the reddish colour.
