Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: Diesel Particulate Filter
  1. #21
    Oct 2010
    Quote Originally Posted by Greg Roles View Post
    That said, if there was no option, then Custom Code still have the only proven delete tune period. I don't care what anyone else claims, even the brand I represent. Only custom code have spent the time to work it out properly, everyone else is using a third party buy in, and I've yet to see one that works properly long term, and I know diesels.
    Are you sure this is still the case Greg? I think there are more companies who are capable of doing it now eg. Shark. It is something that I am looking at doing myself at the moment. I have discovered that a lot of companies try to use a program called "ECU Safe" which supposedly automatically removes the DPF functionality from the ECU file (I think this is the buy in you are referring to). In the case of the Siemens PPD ECUs this seems to not work very well. If you read the ECU safe blog they explain that in an updated version of their software they work around the problem by changing the limp mode torque limiters... No thanks
    edit. Was just reading some forums tonight and it seems that Shark also "remove" the limp mode.. Maybe CC does this too?
    Golf GT Sport TDI
  2. #22
    Jan 2008
    Sunshine Coast
    Feel free to be a test bunny, but if DMS and other HUGE comapnies fail long term, well I know who I would be sticking with. Yes I have heard of Shark, but so too who has run their tune for 20,000kms? Plenty of UK tuners offer it, but from all I have read the regen seems to eventually find a way to turn back on.......and that's a disaster!
  3. #23
    Jan 2011
    Canberra
    Feel like I should post a resolution to this thread - ATPG managed to regen my DPF today when I took it into them. It was brutally clogged - 260-something percent above threshold - but they got it down to about 14% or less on the road. Who knows whether it'll happen again, but I'll try to avoid getting a whole new part until it seems absolutely necessary. They also remapped the car - take a look at the tuning section if you want to hear the results of that...
    Thanks for everyone's input; I hope Zak's DPF problem gets resolved successfully.
  4. #24
    Apr 2009
    Berwick, Victoria
    Hi,
    have read your problem. I have had simlar problems and all at a bad time of
    seeking ongoing surgery. In fact thats why I bought this car was for my medical
    condition and the car allegid reliability.
    Anyway Simlar problems and mine started with the fues tank pump. The one
    submerged in the diesel. I have a thread on this under Diesels and DPF smoking.
    I am at the point of considering legal action against VW. and if so a more the
    merryer (power in n umbers). Read my post, see what you think and if your
    interested in getting together for fact. Then it minght be worth taking this further.
  5. #25
    Jan 2011
    Canberra
    Bump...
    Sigh. I think my DPF has decided that it is, in fact, going to clog up again. Yesterday the particulate light flashed on just for a moment and then disappeared. However, I'm quite sure I can also feel a slight power loss.
    No fault of ATPG, obviously - this DPF just seems to be beyond regeneration, unless it's a sensor fault. I'm taking the car to Sydney on Thursday to have it diagnosed once and for all, since everywhere in Canberra is booked out until hell freezes over. I've decided to take it before it goes into super-clogged limp mode and makes the trip impossible.
    I wanted to ask people's opinion about DPF replacement. Obviously it's illegal to remove the DPF so I won't do that. However, the Sydney mechanic has given me a rough estimate of $2000-2500 to replace it, IF it ends up being the DPF and not a sensor. This has got me to thinking that since this part's apparently a piece of crap anyway, AND results in substantial power and economy losses, what about an aftermarket one? Does anyone have any experience of aftermarket DPFs? I've heard Milltek makes something but from what I can see (Volkswagen Golf Mk5 GT 2.0 TDI 170PS DPF Milltek exhaust) it's just a downpipe, not an actual filter. Also HJS Motorsport.
    I haven't priced any yet - maybe they're even more expensive than VW's part. I know the stock DPF on this engine takes a significant toll in performance and economy so if an aftermarket one resulted in a big improvement I'd consider it well worth the effort, especially since it would leave more leeway for power gains if I later decided to put on a bigger turbo or something insane like that.
    Any input would be much appreciated.
  6. #26
    Oct 2010
    Miltek don't make a replacement DPF they make a straight through down pipe for doing a DPF delete. Don't think anyone supplies aftermarket DPFs, Greg is working on one as he mentioned but not yet.
    My advice, go to your dealership and buy a new G450 sensor. It is under $100 and you can install it yourself. Then drive around at 2500rpm 5th gear or something. Don't know where you got 1750rpm from but that is too low, I'd be wanting AT LEAST 2000rpm. You should be able to see the soot loading drop steadily if you hook up a laptop running VCDS. Hunt someone down in Canberra who has one. You also need VCDS to adapt the ECU to the new sensor.
    Have a look at these two threads for more info:
    http://www.vwwatercooled.org.au/foru...igh-62596.html
    http://www.vwwatercooled.org.au/foru...tml#post714242
    Golf GT Sport TDI
  7. #27
    Jan 2008
    Sunshine Coast
    Get a Vag Com cable. You can then diagnose it yourself, and can force a regen at will, when it suits.
    You can indeed get a DPF from europe under a grand, and fitting is something any half decent Mechanic can do. Still a quote around the $2k mark is pretty good compared to the $4k plus VW wanted for a replacement DPF when they first came out.....
    I have yet to prove my idea of a high flow one will work, but I hope to have drop in standard cores for all the dpf cars in the next few months....not in time to help you though!!
  8. #28
    Jan 2009
    Price hasn't dropped much, it's still around $3700 here just for the part itself.
  9. #29
    Jan 2011
    Canberra
    Thanks for the suggestions, guys. I'll probably get a cable at some point, but right now I don't even have a Windows laptop to run the software. I figure there's really not much point trying to regenerate with this DPF since if it starts to clog up again within a week (assuming it's not a sensor - which I shall find out) it's probably pretty f'ed. I don't want to have to burn it off manually once every 3 days to stay at maximum power. As for the 1750 rev figure, that was what I was told to try first by a VW specialist in Canberra.
    I guess I'll just have to cop the price of a new one if it turns out not to be the sensor - and I don't see any DPFs for this model on eBay. Apparently there's quite a bit of 'precious metal' in DPFs, hence the expense.
    Right now the clogging is rapidly sucking all the power out of my lovely new tune. Can't wait to have this dealt with so I can go and lose my license (like a boss).
    MD
  10. #30
    Oct 2010
