Originally Posted by
jggolf
I have a GT Sport 2.0 TDi .....
They also suggested to take the car for a long run every weekend and that sydney peak hour traffic is no good for the GT's as they like autobaun runs?
Can anyone back this up or were they pulling my leg???
That sounds about right. Lots of UK people are having DPF problems with the 125Kw 2.0 TDI in traffic. There have also been quite a few engines with faulty DPF sensors (pressure sensors IIRC) triggering un-needed regenerations, so not all the problems have been actual clogged DPFs.
If you refrain from giving it a bootful while driving in heavy traffic it will produce less soot and therefore go longer between regenerations. When cruising along the highway at 2,000rpm or more it can do a "passive" regeneration without you knowing. It can also do an "active" regeneration after driving in heavy traffic (it will display a msg on the MDF apparently), and dealers can also do a "forced" regeneration.
If you do some searching you will find lots of info about DPFs and their problems.
Reason: corrected one "DPF" to "MDF" - dammed acronyms !
