Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Diesel Jetta (vege oil)
    May 2006
    Padstow 2211 Sydney
    Here is a waste vege oil jetta click here to go there
    ...And you should definently go here for more on biodiesel too!
    alternate energy vw enthusiast....and general crackpot
    I forgot all about this, but on the last Melb GTG, I bumped into a bloke who lived down my way(or close enough) & was converting his mk1 GLD(which was a one or two owner & very low k's) to run off vege oil or waist cooking oil. One of the two, but he explained to me how he was going to set it up & it look's sort of similar to this setup.
    Jul 2005
    Melbourne, Williamstown
    I'M EXCITED. I'll take 3 thanks.
    Top job.
    mk2 GTi 16v
    Corrado G60
    May 2006
    Maroubra NSW
    Simple idea- wrapping the fuel filter in copper pipe. It would probably be fairly effective. The only problem is, of course, if it gets too cold and your fuel is too viscous to flow quickly enough along the fuel lines from the tank. Would ideally have a tank heater as well.
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
    i love it more of this stuff i say, i hope it becomes common practice we need more bio-fuels
    i just read some of the stuff and i find it really interesting, i am going to try to make a small test batch this coming holidays, i'll keep you posted!
    brackie Guest
    Been there....
    I used rubber hose instead of copper and made a cover for it from a section of 5" plastic irrigation pipe lined with insulation. It worked, but the car still had to be started on diesel and run until the water got hot enough for the canola to thin and flow. I poured the virgin canola straight into the tank and the Red Devil ran beautifully and even now still smells like a fish and chip shop. I've disconnected it all now so I can't show you any pictures. Note... I wouldn't contemplate doing this with dirty oil or even "washed" oil, only virgin.
    May 2006
    Maroubra NSW
    Go Golfman! Get into it. It's really quite easy. If you need any advice, use the Journey to forever website, or ask someone on here.
    I've got my token little jar of biodiesel sitting on my desk to keep me spurred on to finish this project!
    Sep 2006
    Good place for sensible, local advice on biofuels is here:
    http://www.biofuelsforum.com/
    Good place for VW TDI stuff including bio (if you can cope with the seppos and their religious fervour in everything they do):
    http://forums.tdiclub.com/forumdisplay.php?f=52
    Be a bit careful of the journeytoforever, it is reputed to be very political...
    ..Neil
    Audi Q5 2.0 TDI
    sold and missed: '05 Touareg R5TDI
    SWMBO: '08 Golf Pacific TDI DSG
    Quote Originally Posted by smithy010
    yeh mate im pumped to do it this summer? is it initially hard, which oil did you use for your test batch? im tentative to do a first batch, as i am a visual learner i prefer someone to show me how to do it... but if i am successful at it once i can do it better from then on in. It will be a very nervous moment puttin biodiesel in a fueltank.. i think i might trial it as a substitute for 2 stroke oil first just to see how good my batch is then ill start to blend it into my dads fuel... then hopefully get into making bigger high quality batches from waste oil!
    its very exciting i think
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
  3. Jetta FSI Turbo
    By tofo17 in forum Mk5 Golf & Jetta
    Last Post: 04-05-2008, 07:44 PM
  4. Replies: 16
    Last Post: 03-07-2007, 10:31 AM
  5. Petrol or Diesel
    By denilu in forum Mk5 Golf & Jetta
    Last Post: 29-03-2007, 10:33 PM
