Results 1 to 6 of 6
Thread: Diesel injector pump seals
    Apr 2006
    Melbourne, Victoria
    I had some spare time this morning, and a spare injector pump and as my car is leaking fuel, i decided to investigate seal replacement.
    Firstly, clean the pump thoroughly, I assumed that my pump was as corroded inside as out so i didnt bother cleaning it. Big Mistake. Internally the pump was spotless, now it needs a complete rebuild as bits of dust, corrosion and other crud entered the pump.
    To remove the top cover, remove the accelerator lever from the accelerator shaft, noting its alignment on the splined shaft. Undo the four cover screws, tap the cover to break the seal, push the accelerator shaft out of the cover as you lift it off. This gives you access to the accelerator shaft seal, which is an o-ring type.
    Its dimensions are roughly 11mm od, 7mm id and 2mm thick.
    Next i attacked the cold start shaft seal.
    Simply remove the lever arm (noting its position on the shaft), two cover screws, remove the cover and shaft, press the shaft out of the cover and there is the seal, another o-ring of the same dimensions as the accelerator shaft seal.
    This is the cold start shaft cover seal, another o-ring. This seal doesnt have contact with moving parts and probably wont be leaking, however, its dimensions are 32mm od, 26mm id and 3mm thick.
    I have not yet disassembled the pump to acces the input shaft seal (bit daunting). Has anyone had to replace this seal before?
    All of these seals should be available in Viton or equivelant ULSD tolerant compound.
    Any comments are welcome. Also if anyone wants detailed photos of the internals of the pump before they attempt any repairs on their own pump, I am happy to use mine for this educational purpose.
    Matt
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Apr 2006
    Hobart,Tas
    Excellent pics and explanation HiHo. Good on you, thanks, Andrew
    Camden, Sydney
    Yup thanks for sharing the knowledge. Keep it up
    brackie Guest
    Dirt
    Sorry it's taken me so long to reply to this post I've been flat out and neglecting my job.
    Mate, you're one of the few who are courageous enough to go inside a pump! Well done!
    If you intend using this pump on your car you will need to get it a lot cleaner than it is. The dirt that I see in your photos is 10,000,000,000X more than enough to damage the pump and injectors. If you intended to use the pump again the injector pipe unions and banjo fittings should have been plugged and the pump put in a parts washer for as long as you could afford to keep it running, then air blasted and dried before removing any of the cover plates or housings.
    The "top cover" (hydraulic governor housing) seal and the bronze bush in which the throttle shaft runs are the most I've ever had to replace on a VE pump, but that was in the days before ULSD and before I began using a little canola in the tank. Oh, if you replace the bush remember to "Loktite" the new one in.
    Vitron seals should be available. The core of the pump s a little trickier to disassemble and you should make very careful note of parts as you remove them. If you reassemble with care and tighten everything back to the torque at which you removed it you should be able to replace the rotor seals without difficulty. Somewhere I have diagrams of the internals of the VE pump but I'm too busy atm to search them out and scan them. Later perhaps.
    Also, remember to wash the internals of the pump in clean diesel as you assemble it. Even the smallest chip off a screw head or a hair from your head or arm can be enough to cause problems.
    Nov 2010
    California, USA
    This is a common problem the rubber might have been shrunk due to heat or changing temperature the tendency is the seal becomes brittle.
    May 2006
    Adelaide South Australia
    Well done , I really should do mine, it's leaking too. Here's a link to an assy procedure I found some time ago.
    VWDieselParts.com :: View topic - VE injector pump assembly pictures.
    Just reread the original post, over 4 years ago, still my link may help someone.
    Numerous Mk1 Golf diesels
Similar Threads
  1. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
  2. Petrol or Diesel
    By denilu in forum Mk5 Golf & Jetta
    Last Post: 29-03-2007, 10:33 PM
  3. 1.5 diesel Design paper
    By smithy010 in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 13-01-2007, 06:16 AM
  4. Diesel Tacho
    By smithy010 in forum Diesels
    Last Post: 27-08-2006, 11:37 AM
  5. Diesel blowby and runaway... A temporary solution
    By imported_brackie in forum Diesels
    Last Post: 24-06-2005, 10:00 AM
