Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 111
Thread: Diesel fuel additives for modern diesel.
    Adelaide hills, SA
    Every time I met Morey's rep, I asked if the Morey's Diesel Smoke Killer was approved for use in CRD diesel with the DPF and finely Morey's updated their document on the net. The bottles in the shops won't probably mention the DPF but it is now in their data sheet. Morey Oil lubricant product details - MOREYS DIESEL SMOKE KILLER
    So, I can finally start using it in our CRD TDI's wit the DPF.
    Last edited by Transporter; 06-12-2014 at 12:31 PM. Reason: edit title, to make the topic easier to understand
    Oct 2010
    Have been using it my DPF equipped PD for a while now
    Golf GT Sport TDI
    Sep 2006
    I've recently been using Fuel Doctors in my non DPF diesel but have been wondering if to use it in my new Golf (PDF equipped).
    I have nothing against using additives, and have used many over the years but really wonder when you read claims like " can increase power up to 10 HP " I just see this as an invitaion for ridicule.
    Obviously dont need the smoke killing feature with the DPF, but the other claims sound usefull.
    2007 MKV TDI Golf Hatch
    2011 MKVI TDI Golf Wagon
    Adelaide hills, SA
    Anything that helps to burn diesel with less soot, will extend the life of DPF and can save you $$$ in long run.
    Apr 2010
    Rowville,Vic
    I use Morey's in my Tdi following recommndations from different diesel forums about its qualities especially algae inhibitor. It does seem to make the engine run smoother with a bit more kick when freshly added to the fuel. Use it with every tankful nowadays
    MY19 Polo GTi 2.0 DSG
    Previous VW cars:MY16 Polo GTI manual, 2007 Jetta 2.0 TDi manual, 2001 VW Bora V6 4-Motion - flooded away
    Oct 2009
    Como, WA
    How much do you add to per full tank?
    MY10 Golf MkVI 103TDI United Grey
    Adelaide hills, SA
    I think that bottle treats 600L of diesel. There is a scale on the side of the bottle. I usually put a bit more in, it doesn't hurt.
    Apr 2010
    Rowville,Vic
    50ml treats 50 litres. I fill up a 50ml squeeze bottle and put it in the boot in a container and squirt it in the tank before each fill so I get a measured dose every time
    Oct 2009
    Como, WA
    Thanks Transporter & Maxrob200.
    Jan 2008
    Sunshine Coast
    Yeah that's great news, will have to try some while the DPF remains....
