Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 111
Thread: Diesel fuel additives for modern diesel.
  1. #21
    Sydney,NSW
    I like using this one Cleen Diesel - High Performance Diesel Additive
  2. #22
    Adelaide hills, SA
    The key to a healthy fuel system and clean injectors is to use the additive 100% of the time. It's a big task for the "once in 15,000km additive" to clean the injectors in one hit.
    The Penrite DPF Cleaner contains Cerium and should be a very good choice for the DPF equipped diesels.
    As always read the instructions on the bottle.
  3. #23
    May 2007
    Quote Originally Posted by cru22z View Post
    Me too; however it is no longer available for retail sale (straight from the manufacturers mouth!)
    I have now moved on to Moreys' Diesel Smoke Killer!
  4. #24
    Feb 2014
    Central Vic
    So now I'm confused.......Penrite OR Morey's OR both for my 22K TDI Yeti?
    And where to buy at best prices?
  5. #25
    Adelaide hills, SA
    I've moved the 2 stroke oil as an additive posts to its own thread, so please continue the conversation on the 2 stroke oil as an additive there.
    Here is the link for your convenience. Adding 2 stroke oil to fuel - Interesting reading!!
  6. #26
    Oct 2010
    Melbourne, VIC
    Should this thread's title be changed to reflect that it is for diesel specific additives, only? (to prevent any other things like BD and WVGO being introduced)
    Resident grumpy old fart
  7. #27
    Jan 2014
    N/A
    That's a shame, it's the best diesel additive there is and cheaper than the others mentioned so far. The other thread doesn't mention diesel either.
  8. #28
    Adelaide hills, SA
    Quote Originally Posted by CardinalSin View Post
    Yeah, in your car owner's opinion.
  9. #29
    Dec 2009
    Kew, VIC
    I'll still stick to Morey's — and strangely enough it's cheaper than low ash 2-stroke oil.
    More per litre, but you use less of it.
  10. #30
    Jan 2014
    N/A
    Well, yes but there are also many other car owners who agree. That's well documented throughout various forums.
    The opinion of those that actually test the idea, in the real world, is worth more than the unqualified opinions of armchair critics.
