Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 111
Thread: Diesel fuel additives for modern diesel.
  1. #71
    Feb 2014
    Central Vic
    What's the difference with 'truck' diesel I see some Caltex outlets list?
  2. #72
    Jan 2009
    Quote Originally Posted by Ryeman View Post
    It could possibly be referring to fuel bowsers designed for commercial and heavy vehicles, typically featuring larger diameter fuel nozzles and higher flow rates.
  3. #73
    Feb 2014
    Central Vic
    Hmmm, truck was at least 2c cheaper.
  4. #74
    Jan 2009
    My best guess is that the fuel with the lower price is Caltex's regular diesel product, i.e. without the additional additives present in Vortex Diesel.
  5. #75
    Aug 2012
    Perth WA
    The Hi Flow diesel pumps at my local does not fit into the Passat.
  6. #76
    Adelaide hills, SA
    Quote Originally Posted by Amalgam View Post
    Go to Ford dealer and get the small plastic funnel that fits over the pump nozzle. It comes /it was coming with the Focus TD cars.
    It cost less than $10.
  7. #77
    May 2007
    Funny that...it is the only way to put any additives at all into my Mondeo TDCi (with the plastic funnel)!
    As Ford has the EasyFuel Capless Refuelling.
  8. #78
    May 2007
    This is a great thread with some great info.
    As I am no longer able to purchase CleenDiesel Additives I have moved onto the Morey's Diesel Smoke Killer.
    I have also done some more research on easily accessible additives and it seems Flashlube is also available cheaply from Repco etc.
    There seems to be some good info on their site. Has anyone had much to do with Flashlube Diesel Conditioner?
  9. #79
    Jan 2014
    N/A
    I don't have a time to record all data every time I connect the scanner to the vehicle, but in incoming months I will get some life data from those that use the additive all the time and to those who don't, incl. the DPF Cleaner in some TDIs. Of course it will be far from 100% accurate indicator whether it has any impact on the DPF, since many conditions will be different and I wouldn't know how the car was driven.
    But, I can tell right now that my observation is, those who use it? Very rarely have any fuel related problems and sometimes are unaware that there are any DPF problems.
    Looking forward to your results.
  10. #80
    Aug 2012
    Perth WA
    Thanks for the heads up
