My BMN TDI has done 240,000km and it's not caked or bogged up.
Drive it hard and often, and you'll be fine
I've used this product.
Followed the instructions in the vendor's youtube clip:
https://www.youtube.com/watch?v=gsB6-287Kag
Was on my wife's TDI golf, which tends to do quite a few short trips for school bus pickup etc. Had come up with a potential EGR valve fault (although it may have been a bad battery).
Certainly was stuff cleaned up by this - engine responsiveness and power seemed better (confirmation bias perhaps?), but didn't see a measurable change in fuel economy etc. However, the engine fault light hasn't come back.
08 Golf GT TDI
11 (MY12) Passat TDI Wagon
I used it yesterday actually and haven't really noticed any major changes to be honest! I put it in just after the maf but before the turbo. Like you I followed the instruction but can't help but wonder if it may of been better if I'd taken off the egr inlet and sprayed in through that despite the trouble?!
It doesn't break down the baked-on carbon around the EGR.
The oily residue, yes. The sludge, maybe.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Was hoping I could get your opinion on what I might have done wrong trying this Liqui Moly Diesel Engine Decarb spray.
You have already helped me over on my T5 Transporter thread with my 103kw CAAC engine...thanks very much again.
Can I salvage anything from my T5 train wreck
To try and get rid of my EGR fault code, I am about to remove my EGR valve and give it a physical clean.
Before I did that, I wanted to give this spray a go, just in case it was enough.
However because I am still such a novice with T5s and diesel engines, I wasn't sure what was what from your description.
So before I worked that out, I followed the Supercheap video for this spray and sprayed a third of the can into the throttle body.
https://www.youtube.com/watch?v=3agltbN4C7M
Car was still running after this and I took it for a 20km highway run.
Then turned it off and on again a few times as I ran some further VCDS tests.
Right at the end I did a code reset with my final test.
Next day I've started the van and it ran for about 10 seconds, sputtered, then cut out.
Tried it another 5 times and it cuts out after 3 seconds each time as if it's starved for fuel.
Left it for a couple of days and have tried it again.
Same thing happened.
Unless it has returned to my previous immobiliser problem...which was similar...and seemed to fix itself after not being started for 2 years?I seem to have just caused a new problem using Liqui Moly?
Or by performing the codes reset after this?
And I am not sure yet what to try next?
(Also, your suggestion on my other thread to change the engine loom is still on my to do list. I was just trying to exhaust the other easier options first.)
__________________________________________________ __________________________
VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
I think I've answered my own question...but I thought I'd post my conclusion anyway.
I don't believe I've sprayed the Liqui Moly in the wrong area and caused my engine to cut out after 3 seconds every time.
I believe this latest problem is just a coincidence.
And that this is my apparent immobiliser problem resurfacing from 2 years ago.
I have no new error codes since spraying the Liqui Moly.
It ran for 20km on the highway afterwards. And I stopped and started it several times.
Why it chose now to trigger I don't know...but I'll deal with that back on my own thread.
Where I sprayed, the large hose I disconnected from the "throttle valve module" ("throttle body") must come from the air intake/turbo, making it downstream of these and also of the "Air Flow Meter" (MAF sensor).
I followed the afore linked Liqui Moly video on the Supercheap Auto site and these product instructions.
"This should be positioned downstream of the air flow meter/turbocharger/charge air cooler, where possible directly in front of the intake manifold."
It is still possible the Liqui Moly has coated or damaged a sensor but I am not sure which one or what to do about it?
Perhaps a "Throttle Position" sensor and/or an "anti shudder control" sensor?
But if that was the case, others should have reported this over time, and I can't find any real evidence.
It's been suggested I use a "throttle body cleaner" to remove any remaining Liqui Moly.
But which one for a diesel?
I am especially cautious now about spraying anything inside this engine that I don't understand well enough
There was some good information about this subject over on this thread too.
