Thanks guys,
i couldnt have done it without my lovely wife, or my father in laws lovely hilux. Luckily she was asleep during the last leg when the battery went flat!! "Honey" she said, "why arent the lights on?", "they are darlin now go back to sleep". I installed a spare set of brushes and charged the battery and all seems well. Next thing to fix is the speedo which is most likely a broken cable.
The zip tie thing i learned when working on old chain driven twin cam motors. I also zip tied the pump pulley to the pump bracket to prevent any slack in the belt allowing the belt to come off the crank pulley.
The reason the cam locking plate and pump pin would be handy are:
Tightening the cam pully bolt will cause the cam to turn unless you oppose the force with something. I used vice grips on the camshaft. This still may result in the shaft turning and also it also requires eyeballin of the slot in the end of the camshaft to be aligned with the machined cam cover surface. The cam plate does both of these things.
The pump pin would help because at TDC, the spring inside the pump acts to turn the shaft of the pump away from its TDC position. Without a pully on the shaft it is not easy to turn (its not easy to turn WITH a pully on the shaft). This means that one must turn the whole motor to align the key on the pump shaft with the slot on the pump pully. This only applies when doing it on the side of the road and using the zip ties etc.
Hope this makes some sense.
Matt
Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
