"Definately not a moron Smithy. We are to give out advise. No need to mark the flywheel as the bolt hole are offset so the flywheel will only go in 1 position Position the crank with the pistons half way up/down the bores That way you should be able to undo the caps without rotating it. You will haver to reset the cam/pump timing afterwards. You got a manual? We can explain how to reset if you need to know. There are enough of us here to explain!
