Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 49
Thread: Diesel Crank replacement
  1. #21
    May 2006
    Maroubra NSW
    Anyone have a diesel and petrol piston out on the bench?
    I think the old crank is grindable, i've just gotta decide whether a slight imbalance will not be a problem, so it doesn't cost me the cash for a grind.
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
  2. #22
    Camden, Sydney
    It all looks the same smithy. I dont reckon vw would have changed anything they didnt need to. Stuff it in and see how it turns.
  3. #23
    May 2006
    Maroubra NSW
    I thought about it a little more and realised that i have two pistons on one side of the crank and two on the other side, so the crank will be totally mass balanced. There may be some slight imbalances along the shaft... (negligible, according to my advanced mechanics course last year.)
    All good.
    Now to get some bearings, and get this baby running!
  4. #24
    May 2006
    Padstow 2211 Sydney
    Not really, your thinking on a different plane, it's wobble forces would be like one end of the engine up, the other end down. The mass of the piston sortof needs it's own weight balanced as close to the piston as possible, as you transfer it along the crank you get wobbles in other planes...don't you?
    alternate energy vw enthusiast....and general crackpot
  5. #25
    May 2006
    Maroubra NSW
    That's what i meant by unbalance along the shaft. You're right in this way. I probably overstated it by saying it would be negligible, but the difference may not be much.
    Hopefully the mass of the pistons will not be sufficiently different to upset the "wobble" along the crankshaft.
    What do you think edison?
  6. #26
    May 2006
    Padstow 2211 Sydney
    Stand back and crank it...
  7. #27
    Camden, Sydney
    Its not a high performance engine, I reckon it`ll work.
    Get some bearings.
  8. #28
    May 2006
    Maroubra NSW
    Yep. 190 or so from tooleys for mains, big ends, and a bottom end kit.
    Things are tough when you've gotta save up for something like that!
  9. #29
    Camden, Sydney
    Cheaper in the UK.
    I can hook you up, or do some internet research.
  10. #30
    May 2006
    Maroubra NSW
    How about sharing your source loon?
    I've found a pretty good place in the states... 100AU for Big ends, mains, gaskets, seals, and engine mount rubbers (left and right). Waiting for a quote on postage.
Similar Threads
  1. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
  2. Petrol or Diesel
    By denilu in forum Mk5 Golf & Jetta
    Last Post: 29-03-2007, 10:33 PM
  3. Diesel Tacho
    By smithy010 in forum Diesels
    Last Post: 27-08-2006, 11:37 AM
  4. Diesel Crank
    Last Post: 16-07-2006, 09:01 PM
