Results 1 to 4 of 4
Thread: Diesel cooling system
    May 2006
    Maroubra NSW
    Hi all,
    Sorry to bombard you with constant questions, but i'm wondering whether the diesel cooling system is the same as the petrol's.
    Does anyone know whether the temp gauge has the same calibration?
    Also, has anyone had bad experience with running in hot conditions, ie, is the cooling system adequate, cos if it isn't, i will consider putting a bigger radiator in.
    Just reading through some of the 2005 forums, and i was surprised to see the types of people on the diesel forum. GLDGTI is a uni student in mechanical engineering (correct me if i'm wrong), and so am i (at UNSW), and a lot of you are country folk or from farms, which i am too. Quite amazing how these forums bring similar people together!
    Cheers all.
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
    brackie Guest
    Cooling systems
    Quote Originally Posted by smithy010
    Hi all,
    Not all petrols. The diesel has the expansion/degassing tank. Older petrols don't. Water pump is the same but diesels have a bigger radiator.
    No..... I've read that it doesn't. The diesel head has thicker metal around the precombustion chambers and cooling jacket. This means it absorbs heat more quickly but transfers it to the water jacket more slowly. The sender and gauge are calibrated accordingly.
    I had diesels (one with aircon) in country WA when it was 44C in the waterbag and they never overheated. As long as everything is up to specs and the core is clean inside and outside you shouldn't have a problem.
    Cheers all.
    Sure do! That's what forums are all about.
    Gosford Central Coast NSW
    what year are you in? i'm in 3rd year.....aaaaarrrrrgggggghghhh
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    May 2006
    Maroubra NSW
    4th year. Thesis year.!
    Designing suspension for the UNSW solar car.
Similar Threads
  1. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
  2. Petrol or Diesel
    By denilu in forum Mk5 Golf & Jetta
    Last Post: 29-03-2007, 10:33 PM
  3. Flashing cooling system light??
    By pommy_golfer in forum Mk3 Golf & Vento
    Last Post: 13-03-2007, 06:21 PM
  4. Diesel Tacho
    By smithy010 in forum Diesels
    Last Post: 27-08-2006, 11:37 AM
  5. Diesel blowby and runaway... A temporary solution
    By imported_brackie in forum Diesels
    Last Post: 24-06-2005, 10:00 AM
