This one's cheap.
AMA 2.5cc DIESEL ENGINE 1955 CZECH REPUBLIC | eBay
Here is a good one. I had a customer come into work with the idea of changing his petrol Moke into a diesel. Could anyone suggest a great little diesel engine that might be suitable. Just out of general curiosity.
His only rule is it must be light and as "inexpensive" as possible lol
Rising Blue MY10 Passat R36
BLACK '97 Mk3 GL 2.0L
White '82 MK1 Cabrio 1.8L
Vice-President - VWDCQ (VW Drivers Club of Queenland inc)
This one's cheap.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
5000 rpm? What with LPG and NOS? Pretty big revs for autoignition!
Rofl Neil i think thats a little too small lol. Kinda cool though.
Thanks gldgti I'll let him know. I knew the answer laid within a VW Golf.
no mate, thats stock from vw. max revs 5500.
the vw indirect injection diesels rev fast quite easily. much nicer than the tdi's which really are tractors.
Ironman, I have a complete 1.5lD sitting on my garage floor, and parts enough to build a few others. let me know if you need something. the 1.5/1.6 D is by far the smallest and lightest vw diesel that you'll find in australia, thats also very simple.
'99 A4 Quattro 1.8T
also - if it was me doing it, i'd get the mk1 golf gearbox aswell. And i'd put it in the back![]()
'99 A4 Quattro 1.8T
Also try Holden Gemini Isuzu, there's a few diesel engines about, and may be easier to get more as they come from Japan
Mk3 Golf Tdi about to sell
Mk 1 Golf GLD somewhere in a paddock!
Mk1 Golf Cabriolet
MK2 Golf Turbo diesel engine and 5 sp gearbox
The biggest problem putting a different engine into a Moke, or early Mini for that matter is the increase in weight.
A standard 1275 Moke/Mini engine complete with gearbox and accessories weighs a fraction over 150kg. Increasing this weight significantly will cause the rubber cone suspension to collapse so a relatively simple engine swap might turn into a project that also involves changing the suspension as well.
There’s a few places in the UK and US making sub-frames for Mini’s that are designed to take different engines that incorporate coil overs, this may be worth investigating. The most common conversion these days is to fit the 2 litre Honda VTEC engine.
Does Honda do a VTEC that runs on diesel these days?
Mk1 Golf Cabriolet
