Results 21 to 30 of 38
Thread: Diesel city driving anyone?
  1. #21
    Nov 2007
    Good point Greg. But for these car owners who keep their without DPF car longer than 3years, maintaining injectors as clean as possible will be beneficial too, since dirty injectors will disturb injection pattern, which will lead to more unburned fuel polluting the oil in the crankcase, wearing out engine prematurely and more blow by gases with sludged oil will enter intake system.
    Always use a good diesel additive it will pay for itself.
    But for these who trade in when 3 years are up, don't worry too much about it, do what the owners manual says in regard to maintenance.
    You use an additive for every tank fill? What's this additive for? How much does it cost and why a specific one for DPF cars?
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
  2. #22
    Adelaide hills, SA
    Quote Originally Posted by poyta View Post
    Yes, every time I fill up.
    To keep the fuel system clean.
    From $15 to $25, some are concentrated and will treat on average 600L of fuel. You want to make sure that they're compatible with DPF.
  3. #23
    Oct 2010
    Melbourne, VIC
    From Supercheap: Fuel Doctor, LiquiMoly, Moreys Diesel Engine Smoke Killer, Lucas Injector cleaner and upper cylinder lubricant.
    From Repco: LiquiMoly
    I use WURTH CRD Additive if you have DPF and Diesel Additive without DPF. All above are good I use them.
    Have you had any experience or heard from others about the diesel fuel additives by HiFlo or Redline?
  4. #24
    Adelaide hills, SA
    No.
    Redline is quite expensive and as long as what I use does a good job, I don't have a reason to change to another brand.
    I also use InterJect petrol and diesel additives. InterJect Interjectron additive for petrol is absolutely the best additive I've ever used, I'm using it for +10 years now.
  5. #25
    Nov 2007
    Yeah but how can you tell that an additive is doing a good job?
  6. #26
    Just bought a polo tdi DSG - does the dsg take car of having to rev it hard every so often ?
    Driving it back from Victoria on Friday so all advice welcome...
  7. #27
    Oct 2010
    Melbourne, VIC
    It doesn't seem to prevent DPF regens on our 103kW MkVI Golf when using Drive mode.
    Do you intend to drive back by the Hume Hwy? It would probably help run in if you went a more circuitous route like the Monaro Hwy via Princes Hwy.
  8. #28
    Adelaide hills, SA
    From my experience, observation and from continuous questioning.
    I use them everyday in many different makes and models and my customers are happy customers.
    I also use them in our family and friends cars and I always ask many question before I service them. My T5 after 80,000km has the same fuel economy as when it was new and it is running really well, the engine is very quiet compared to some T5's I saw and there is not much smoke on start up when cold.
  9. #29
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by kaanage View Post
    Absolutely, come home via the hills in a new car, make it work, those first few hundred k's are vital!
  10. #30
    Nov 2007
    Well ok...bought some "fuel Doctor" today and will give it a go. Mine has recently shown quite a reduction in Fuel economy so maybe this stuff will help. Funny that the directions on the bottle don't specify how much to add - it just says add 25ml to a tank but doesn't specify what size tank.
