The main problem is your DPF. It likes to get hot, and it gets hot on longer, higher speed runs. They seem to clog by 100k worst case, and are expected to last 150k according to VW. If you intend to keep the car longer than this, it's a concern, if not, then don't worry about it. Also, if it's a manual, you can drive to suit, keeping the revs over 1800, below which you're producing a lot of soot when you put your foot down. I tend to drive in 3rd in the city / below 60kph in hills to keep the revs up and the soot minimal, and it does feel weird. The diesel has the catch 22 in that it will pull from down low, but soot itself whist doing so, and it ends up in the DPF. as this soot is never 100% removed, and slowly builds up, it's only a matter of time. Finally if you fit a Provent from new to minimise the oil blowby, which again ends up in your DPF as well as clogging up the intake, you stand the best chance of prolonging your DPF's lifespan.
